| Mismatch Debug Configuration->Source Lookup Path vs. Project->Source Location? [message #229611] |
Wed, 28 January 2009 06:17  |
I have a Makefile C++ project (named myproject) where my working directory
is not the root of the project, say
${workspace_loc:/myproject/examples/ex_current} (as appears in Project ->
Properties -> C/C++ Build -> Builder Settings (tab) -> Build directory).
Currently, this directory contains some of the sources, the executable,
and my input/output files for execution.
I have another directory /myproject/examples/ex_base/ex_base1 (the first
"/" not meaning the root of the filesystem, but being in the project
directory) with all the same files. It is a base version that I have
replicated for testing purposes, so ex_current has slightly modified files.
The problem is that when I debug my executable, sometimes the debugger
shows me sources in /myproject/examples/ex_base/ex_base1 instead of
/myproject/examples/ex_current. I do not find where to let Eclipse know
which are the right sources. I could remove ex_base/ex_base1, or move it
somewhere else, but I would like to know how to control Eclipse more
precisely. The things that I have done after duplicating the directory
from ex_base/ex_base1 to ex_current, that I thought could solve my problem
(and did not) are:
1- Remove all *.d dependency files and recompile the whole project, to
make sure there were no object files pointing to base sources. I did this
from outside Eclipse, at a Cygwin bash command line.
2- For the project, in Properties -> C/C++ General -> Paths and Symbols ->
Source Location (tab), under the folder myproject, I have added the
folders /ex_base and /ex_base/ex_base1 to the filter.
3- Project -> Index -> Rebuild
4- Project -> Index -> Freshen all files
5- Project -> Refresh
After doing all this, my Debug Configurations -> Source (tab) still showed
the filtered directories of point 2 in the Source Lookup Path, under
Default -> myproject. There were actually other directories that I had
also filtered. There seems to be a disconnect between the directories that
show up in the Source Lookup Path for a Debug Configuration and the Source
Location for a Project.
I will describe a little bit more my project, which may help finding the
causes for the problem. I have a main file main.c, some C sources and some
C++ sources. Another symptom of the duplicity is the following. While I am
debugging, say, a function F1 in main.c, and I enter from there a function
F2 in source src1.c, Eclipse goes to ex_base/ex_base1/src1.c instead of
ex_current/src1.c. The stack in the Debug tab consistently (and
erroneously) shows ex_base/ex_base1/src1.c. On the other hand, if I hover
over the call to F2 in main.c, and Control-Click on F2, it correctly goes
to ex_current/src1.c. All this is for a src1.c which is exactly the same
in both directories. Now for another src2.cc which was slightly changed,
when entering F3 in src2.cc, the debugger goes to the wrong
ex_base/ex_base1/src2.cc, but it shows the correct entry line number, both
in the editor window and the debug stack, so the whole debugging becomes
messy.
Any hint on this?
FUDForum. Page generated in 0.03688 seconds
