Home » Archived » M2M (model-to-model transformation) » [ATL] "Warning, could not find mathing node for ForEachOutPatternElement..."
[ATL] "Warning, could not find mathing node for ForEachOutPatternElement..." [message #22356] Fri, 09 March 2007 04:55 Go to next message
I'm working on a transformation which use a CalledRule to factorize some
operations.
When I compile it, I've got this error :
"Warning, could not find matching node for ForEachOutPatternElement in
mode calledRuleCreate" and "... in mode calledRuleInit"
It reports "ERROR: no slot reserved for variable: view used at
XX:XX-XX:XX" for my first Target pattern and the same for the second
pattern.
Here is the code of my CalledRule :
rule Entities(c : asur!ComputerSystem) {
using {
sources : Sequence(asur!DataExchangeRelation) =
c.relationShipSources->select(r|r.oclIsKindOf(asur!DataExchangeRelation)
and r.target.oclIsKindOf(asur!AOut));
targets : Sequence(asur!DataExchangeRelation) =
c.relationShipTargets->select(r|r.oclIsKindOf(asur!DataExchangeRelation)
and r.source.oclIsKindOf(asur!AIn));
to
view : distinct asurIL!E_View foreach(e in sources) (
Name<-'V_'.concat(c.Name.concat('To'.concat(e.target.Name))),
Module_ID <- 'null'
control : distinct asurIL!E_Control foreach(e in targets) (
Name<-'C_'.concat(e.source.Name.concat('To'.concat(c.Name))),
Module_ID <- 'null'
do {
thisModule.model.components <- view;
thisModule.model.components <- control;
"asur" is my source metamodel and "asurIL" my target metamodel.
When I use this code in my MatchedRule, it works fine, but when I define
this CalledRule, I've got this error.
I call it in the "do" section of 3 Matched rules.
If you see something bad, please tell me where I'm wrong.
Thank you
Guillaume
Re: [ATL] "Warning, could not find mathing node for ForEachOutPatternElement..." [message #22436 is a reply to message #22356] Fri, 09 March 2007 05:57 Go to previous messageGo to next message
I found bug 147313 which talk about iterative patterns and "Lazy rules",
which I don't know what is it about.
Are Iterative target patterns in CalledRules implemented in ATL ?
The manual says yes !
Any idea ?
Guillaume
Guillaume Gauffre a écrit :
> operations.
> pattern.
> using {
> to
> Module_ID <- 'null'
> Module_ID <- 'null'
> do {
> Thank you
> Guillaume
Re: [ATL] "Warning, could not find mathing node for ForEachOutPatternElement..." [message #25456 is a reply to message #22436] Fri, 23 March 2007 18:54 Go to previous message
Iterative patterns are deprecated. They still work with standard rules
to provide compatibility with existing transformations, but they do not
work with features that have been introduced later like lazy rules and
called rules.
In your case, you could create one rule to create an E_View and another
rule to create an E_Control. Then, you can call these rules within a for
statement.
Here is a simplified example in which I only handle the sources:
rule CreateView(e : asurIL!E_View, prefix : String) {
to
view : asurIL!E_View foreach(e in sources) (
Name<-'V_'.concat(prefix.concat('To'.concat(e.target.Name))),
Module_ID <- 'null'
do {
view;
using {
do {
for(e in sources) {
thisModule.model.components <- thisModule.CreateView(e, c.Name);
Frédéric Jouault
> Any idea ?
> Guillaume
>> some operations.
>> pattern.
>> using {
>> to
>> Module_ID <- 'null'
>> ( Name<-'C_'.concat(e.source.Name.concat('To'.concat(c.Name))),
>> Module_ID <- 'null'
>> do {
>> define this CalledRule, I've got this error.
>> Thank you
>> Guillaume
Previous Topic:[ATL]Load Model Problem in ATLEMFModelHandler
Next Topic:[ATL]Does ATL Engineer always transfer "Element"(SimpleType) to "Attribute" ?
Current Time: Wed Sep 17 23:05:44 EDT 2025
Powered by FUDForum. Page generated in 0.05657 seconds
