Home » Eclipse Projects » JFace » Bind TableViewer to Multiple Objects?
Bind TableViewer to Multiple Objects? [message #22351] Tue, 21 July 2009 10:00 Go to next message
First off a little background of what I'm trying to do. I have an RCP that
is modeling a spacecraft trajectory. The trajectory is broken into
sections (Class TrajSection) and each section has its own planet (Class
Planet) and much other stuff. For many sections the Planet will be
"Earth". I have a view that opens to show the details about the planet
which includes tables. I have been able to bind the tables to the planet
using the methods in snippet 13
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.e xamples.databinding/src/org/eclipse/jface/examples/databindi ng/snippets/Snippet013TableViewerEditing.java?view=markup
My problem arises because I only want one view to be open at a time for
each planet name, (AKA only one for Earth, Mars etc), but if "Earth" is
open I want that View to be bound to all planets with name "Earth". I have
been able to loop through all the sections and bind the planets components
for items using Text widgets but when I try to bind the tables to multiple
planets I get null pointer exceptions or this
assertion failed: Getter called on disposed observable
org.eclipse.core.internal.databinding.beans.BeanObservableMa pDecorator @58aa17c3
Here is a little code to show what I have. (I'm using SWT forms as well)
grav_cTable = toolkit.createTable(planetClient, SWT.BORDER);
grav_cTable.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true, 1,
6));
grav_cNames = new String[] {"one", "two", "three"};
grav_cViewer = new TableViewer(grav_cTable);
for(int i = 0; i < sectionList.size(); i++) {
if
(planet.getName().equals(sectionList.get(i).getPlanet().getN ame())) {
if (grav_cTable.getColumnCount() < 1) {
for (int j = 0; j < 3; j++) {
grav_cColumn = new TableViewerColumn(grav_cViewer,
SWT.NONE);
grav_cColumn.setEditingSupport(new
InlineEditingSupport(grav_cViewer, bindingContext, grav_cNames[j]));
grav_cColumn.getColumn().setWidth(100);
ViewerSupport.bind(grav_cViewer, new
WritableList(TrajectoryGUI.getDefault().getActiveTrajectory( ).planetList.get(i).getGrav_c(),
Grav_C.class),BeanProperties.values(Grav_C.class, grav_cNames));
else {
I would like to keep the same structure of Section having an instance of
Planet because I use a TreeView to show the breakdown of the trajectory
structure, Unless there is another way of doing that. I'm not sure if this
is possible or if this is the best way of doing this. If you couldn't tell
I'm Aerospace not Computer Science so if you have any ideas I open for
advice. Thanks in advance for any help and let me know if you need more
code or explanation.
Stephen
Re: Bind TableViewer to Multiple Objects? [message #23030 is a reply to message #22351] Wed, 22 July 2009 15:49 Go to previous messageGo to next message
If two sections have an "Earth" planet reference, are they both pointing to
the same planet instance? If so, you only need to bind once. If not, i.e.
if the two "Earth" planets can have different properties, then I don't see
why you would want to bind them to the same viewer.
"Stephen Panosian" <stephen.panosian@gmail.com> wrote in message
news:2c5400ecc886fa3d23e000c5d86317aa$1@www.eclipse.org...
> 6));
> if (planet.getName().equals(sectionList.get(i).getPlanet().getN ame()))
> SWT.NONE);
> else {
> Stephen
Re: Bind TableViewer to Multiple Objects? [message #23577 is a reply to message #23030] Thu, 23 July 2009 09:29 Go to previous message
Hey,
thanks for the input. I realized organizing my project with a database
like object that centralized all the planets would be better in the long
run. Before I was creating multiple instances of planet. Now I only need
to bind once. I appreciate your input though. Thanks again.
Stephen
Previous Topic:Section gets larger when expand
Next Topic:Validate text in TextCellEditor after input
Current Time: Fri Nov 21 06:21:52 EST 2025
Powered by FUDForum. Page generated in 0.04089 seconds
