| Problem Running Transformations [message #22347] |
Mon, 13 July 2009 15:23  |
IŽm trying to run the examples but, always I get the same problem.
Any help will be appreciates.
org.antlr.runtime.CommonTokenStream.fillBuffer(CommonTokenSt ream.java:95)
at org.antlr.runtime.CommonTokenStream.LT(CommonTokenStream.jav a:238)
org.eclipse.epsilon.eol.AbstractModule.invokeMainRule(Abstra ctModule.java:182)
at org.eclipse.epsilon.eol.AbstractModule.parse(AbstractModule. java:142)
org.eclipse.epsilon.evl.dt.launching.EvlLaunchConfigurationD elegate.launch(EvlLaunchConfigurationDelegate.java:49)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:853)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:703)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:866)
org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1069)
| Re: Problem Running Transformations [message #22607 is a reply to message #22563] |
Mon, 13 July 2009 17:10  |
Hi Marcellus,
I can't seem to be able to reproduce this... I checked out the example
and the org.eclipse.epsilon.examples.metamodels project, registered
OO.ecore, right-clicked ValaidateOO.launch and clicked Run As ->
ValidateOO and it ran as expected. I'm starting to run low on ideas on
what may be wrong...
Dimitris
Marcellus Castro wrote:
> It's the validateoo example. I can run the validation only if I create a
> ant task for it.
> Cheers
| Re: Problem Running Transformations [message #570584 is a reply to message #22347] |
Mon, 13 July 2009 15:46  |
Hi Marcellus,
This happens when the program specified in the source tab of the launch
configuration does not exist. My guess is that you have imported/checked
out the examples but with different project names. You can either
re-import them using their default names, or update the launch
configurations accordingly.
In any case, it should fail more gracefully than throwing an exception,
so I'll open a new bug report to keep track of this.
Dimitris
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
| Re: Problem Running Transformations [message #570631 is a reply to message #22475] |
Mon, 13 July 2009 16:29  |
Hi Marcellus,
Which example is that? Have you checked it out from the SVN or
downloaded a .zip file?
Dimitris
> Hi Dimitris, Thx for the answer!
> I believe that the is not that. The configuration is correct but the
> problem still is occurring.
| Re: Problem Running Transformations [message #570671 is a reply to message #22563] |
Hi Marcellus,
Dimitris
> ant task for it.
> Cheers
FUDForum. Page generated in 0.05447 seconds
