Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Using JET to create java Code
Using JET to create java Code [message #22190] |
Tue, 14 February 2006 19:26  |
Originally posted by: ed.ed4becky.org
And I am trying to find if there is a Best Practice way to reformat the
output accordinging to the Java Editor format selected by the user.
Re: Using JET to create java Code [message #22340 is a reply to message #22190] |
Wed, 15 February 2006 07:17   |
--------------070809050302050806010101
Ed,
It's quite easy to invoke the formatter programmatically.
You can create a formatter using
org.eclipse.jdt.coreToolFactory.createCodeFormatter(codeForm atterOptions)
and then apply it like this:
protected static String formatCode(String contents,
CodeFormatter codeFormatter)
IDocument doc = new Document(contents);
TextEdit edit =
codeFormatter.format(CodeFormatter.K_COMPILATION_UNIT, doc.get(), 0,
doc.get().length(), 0, null);
try
edit.apply(doc);
contents = doc.get();
catch (Exception exception)
CodeGenEcorePlugin.INSTANCE.log(exception);
return contents;
> the output accordinging to the Java Editor format selected by the user.
<html>
<head>
</head>
Ed,<br>
<br>
It's quite easy to invoke the formatter programmatically.<br>
<br>
and then apply it like this:<br>
<blockquote><small> protected static String formatCode(String
contents, CodeFormatter codeFormatter)</small><br>
<small> {</small><br>
<small> IDocument doc = new Document(contents);</small><br>
<small> TextEdit edit =
doc.get().length(), 0, null);</small><br>
<small> </small><br>
<small> try</small><br>
<small> edit.apply(doc);</small><br>
<small> contents = doc.get();</small><br>
<small> }</small><br>
<small> catch (Exception exception)</small><br>
<small> CodeGenEcorePlugin.INSTANCE.log(exception);</small><br>
<small> return contents;</small><br>
</blockquote>
<br>
Ed Thompson wrote:
<blockquote cite="middstsf1$e8g$1@utils.eclipse.org" type="cite">And I
<br>
</blockquote>
<br>
</body>
</html>
--------------070809050302050806010101--
Re: Using JET to create java Code [message #22596 is a reply to message #22340] |
Wed, 15 February 2006 17:56   |
Thanx Ed, this looks great!
I have just started in the world of code generation, and am having a lot
of fun with it. Appreciate the help!
Ed Merks wrote:
> Ed,
> TextEdit edit =
> try
> edit.apply(doc);
> return contents;
Re: Using JET to create java Code [message #22682 is a reply to message #22340] |
Wed, 15 February 2006 19:54   |
Ok, getting a wierd error when I try this:
String buffer = rmt.generate(bean);
CodeFormatter codeFormatter = ToolFactory.createCodeFormatter(null);
I am running it in a jUnir test just to test the concept. Googling
comes up with a ned to initialize something, but not sure what..
java.lang.ExceptionInInitializerError
at org.eclipse.jdt.core.JavaCore.getOptions(JavaCore.java:2401)
org.eclipse.jdt.core.ToolFactory.createCodeFormatter(ToolFac tory.java:96)
org.ed4becky.codegen.TestModelBeanTemplate.testGenerate(Test ModelBeanTemplate.java:39)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:478)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:344)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Caused by: java.lang.NullPointerException
org.eclipse.jdt.internal.core.search.indexing.IndexManager.g etJavaPluginWorkingLocation(IndexManager.java:284)
org.eclipse.jdt.internal.core.search.indexing.IndexManager.<init >(IndexManager.java:50)
org.eclipse.jdt.internal.core.JavaModelManager.<init>(JavaModelManager.java:671)
org.eclipse.jdt.internal.core.JavaModelManager.<clinit>(JavaModelManager.java:649)
... 18 more
Ed Merks wrote:
> Ed,
> TextEdit edit =
> try
> edit.apply(doc);
> return contents;
Re: Using JET to create java Code [message #22856 is a reply to message #22682] |
Thu, 16 February 2006 05:25  |
Ed,
Are you running in a headless Eclipse rather than stand-alone? That's
required for JDT to function properly.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 18 more
> Ed Merks wrote:
>> Ed,
>> TextEdit edit =
>> try
>> edit.apply(doc);
>> return contents;
Re: Using JET to create java Code [message #566785 is a reply to message #22190] |
Tue, 14 February 2006 21:22  |
Ed,
If you want to use the Sympedia Generator Framework,
then you can simply configure a generator pipeline with a Java Formatter.
Please have a look at http://genfw.berlios.de
Cheers
/Eike
Re: Using JET to create java Code [message #566896 is a reply to message #22190] |
Ed,
TextEdit edit =
try
edit.apply(doc);
return contents;
<html>
<head>
</head>
Ed,<br>
<br>
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Re: Using JET to create java Code [message #567127 is a reply to message #22340] |
Ed Merks wrote:
> Ed,
> TextEdit edit =
> try
> edit.apply(doc);
> return contents;
Re: Using JET to create java Code [message #567173 is a reply to message #22340] |
... 18 more
Ed Merks wrote:
> Ed,
> TextEdit edit =
> try
> edit.apply(doc);
> return contents;
Re: Using JET to create java Code [message #567318 is a reply to message #22682] |
Ed,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 18 more
> Ed Merks wrote:
>> Ed,
>> TextEdit edit =
>> try
>> edit.apply(doc);
>> return contents;
Current Time: Mon Jul 21 22:02:56 EDT 2025
Powered by FUDForum. Page generated in 0.07294 seconds
