Home » Newcomers » Newcomers » Jobs and Scheduling
Jobs and Scheduling [message #227323] Tue, 14 August 2007 11:19 Go to next message
Originally posted by: bkheck.gmail.com
Hi all. I have an import wizard that does some searching for a specific
file extension. I am trying to show a ProgressIndicator to the user to
indicate that the searching is taking place, as the search may take a
long time depending on the directory being searched. I found out the
hard way that if I call ProgressIndicator.beginAnimatedTask() and then
call my search, they both run in the UI thread and the ProgressIndicator
is not displayed. I am now trying to use a Job for my searching so that
I can display the ProgressIndicator to the user while the searching is
going on. The problem I'm having now, however, is that
ProgressIndicator.done() is being called before the search begins, and
the ProgressIndicator is not being displayed. The basic flow is as follows:
progressIndicator.beginAnimatedTask();
Job searchJob = new Job("Searching") {
protected IStatus run(IProgressMonitor monitor) {
searcher.search(directory);
searchJob.schedule();
progressIndicator.done();
I have read some articles about jobs and I have searched the e.platform,
e.rcp, and e.swt newsgroups for someone having a similar problem, but I
can't find anything that I have been able to apply to the situation that
I am in. Can anyone help?
Thanks in advance,
Brandon
Re: Jobs and Scheduling [message #227362 is a reply to message #227323] Tue, 14 August 2007 16:45 Go to previous messageGo to next message
Brandon,
I'm not sure whether it'll work in your case or not but you can try this
return Status.OK_STATUS;
searchJob.addJobChangeListener(new JobChangeAdapter() {
public void done(IJobChangeEvent event) {
if (event.getResult().equals(Status.OK_STATUS)) {
All this does is that it ensures that progressIndicator.done() gets
called only when job is finished.
Hope that helps.
-tanmay
> @Override
> Thanks in advance,
> Brandon
Re: Jobs and Scheduling [message #227369 is a reply to message #227362] Tue, 14 August 2007 17:07 Go to previous message
Thanks Tanmay. That worked!
Brandon
Tanmay Sinha wrote:
> Brandon,
> @Override
> @Override
> Hope that helps.
> -tanmay
>> specific file extension. I am trying to show a ProgressIndicator to
>> the user to indicate that the searching is taking place, as the search
>> may take a long time depending on the directory being searched. I
>> found out the hard way that if I call
>> ProgressIndicator.beginAnimatedTask() and then call my search, they
>> both run in the UI thread and the ProgressIndicator is not displayed.
>> I am now trying to use a Job for my searching so that I can display
>> the ProgressIndicator to the user while the searching is going on. The
>> problem I'm having now, however, is that ProgressIndicator.done() is
>> being called before the search begins, and the ProgressIndicator is
>> @Override
>> e.platform, e.rcp, and e.swt newsgroups for someone having a similar
>> problem, but I can't find anything that I have been able to apply to
>> the situation that I am in. Can anyone help?
>> Thanks in advance,
>> Brandon
Previous Topic:Using Eclipse as a Platform
Next Topic:Need Help Configuring Eclipse to Debug Plugin (Command Line)
Current Time: Sun Aug 31 21:27:52 EDT 2025
Powered by FUDForum. Page generated in 0.08417 seconds
