Home » Eclipse Projects » Technology Project and PMC » [Stellation] tar file corrupted
| Re: [Stellation] tar file corrupted [message #23660 is a reply to message #23617] |
Fri, 13 September 2002 02:29   |
Originally posted by: jed.wesley-smith.remove.remove.combined.com.au
Eclipse does not use any particular CMS, it uses a CMS abstraction layer.
This CMS abstraction layer is currently implemented by CVS, ClearCase, PVCS
and a whole heap of others... Stellation is just another CMS that can be
used by Eclipse that happens to be written using Eclipse (I believe...).
Stellation shows great promise as a CMS, but is still alpha/beta technology
and should not be used by any production level development efforts unless
prepared to deal with the risks associated with using such new technology.
To give an idea how 'green' Stellation still is, the official Stellation
source is still kept under CVS control.
bewdy,
- jed.
"Alin" <asimionoiu@attbi.com> wrote in message
news:alru3m$g93$1@rogue.oti.com...
> I'm curios why Eclipse is still using cvs and not stellation..
> Or maybe I didn't understand what stellation is..:)
> Alin
> "Mark C. Chu-Carroll" <markcc@bestweb.net> wrote in message
> news:alq4hu$ir6$4@rogue.oti.com...
> > On Mon, 09 Sep 2002 14:38:25 +0000, Davide Varvello wrote:
> > > Shane Curcuru wrote:
> > >> Works fine for me. Have you tried a different version of tar? You
may
> > >> need to use a GNU-compatible one that handles long filenames (over
100
> > >> chars).
> > > Thanks, I'll try it.
> > That tar file is *very* out of date. You really don't want it. There's
> > a major bug in the current tarfile version that has been fixed in CVS.
> > We haven't been updating the tar file, because things have been so
> > in flux. We seem to be approaching a state where it will make sense
> > to declare a new stable version.
> > In the meantime, please get the latest from CVS. If you need help,
> > I'll be glad to give you directions.
> > -Mark
> > Mark Craig Chu-Carroll, IBM T.J. Watson Research Center
> > *** The Stellation project: Advanced SCM for Collaboration
> > *** http://www.eclipse.org/stellation
> > *** Work Email: mcc@watson.ibm.com ------- Personal Email:
> markcc@bestweb.net
| Re: [Stellation] tar file corrupted [message #23706 is a reply to message #23660] |
Fri, 13 September 2002 02:37   |
Originally posted by: asimionoiu.attbi.com
Actually my question (more a curiosity) was why the eclipse project/projects
are still kept in CVS
and not using stellation.
But I think that you have answer this in here when you said that stellation
is still alpha/beta.
From I have read on the web it seems that stellation project will be
something great.
I'll have to try it this days.
Alin
"jed" <jed.wesley-smith.remove@remove.combined.com.au> wrote in message
news:alrvho$grr$1@rogue.oti.com...
PVCS
technology
> bewdy,
> - jed.
> > Alin
> may
> 100
> > > >> chars).
> > > -Mark
> > markcc@bestweb.net
| Re: [Stellation] tar file corrupted [message #24031 is a reply to message #23660] |
Fri, 13 September 2002 17:47  |
> layer. This CMS abstraction layer is currently implemented by CVS,
> ClearCase, PVCS and a whole heap of others... Stellation is just another
> CMS that can be used by Eclipse that happens to be written using Eclipse
> (I believe...). Stellation shows great promise as a CMS, but is still
> alpha/beta technology and should not be used by any production level
> development efforts unless prepared to deal with the risks associated
Well, actually, there's slightly more to it than that. Beyond the
simple functionality issues, there's a major political/bureaucratic
issue involved in installing a Stellation server on Eclipse.
We've used Stellation for the IBM internal work on Stellation. If
we could install a Stellation server on the eclipse site, we'd probably
do it within a couple of weeks. But I suspect that it will take at least
a few months to convince the Eclipse sysadmins that our system can be
trusted to run securely without compromising their servers.
-Mark
*** Work Email: mcc@watson.ibm.com ------- Personal Email: markcc@bestweb.net
| Re: [Stellation] tar file corrupted [message #576167 is a reply to message #22447] |
Mon, 09 September 2002 10:38  |
> Works fine for me. Have you tried a different version of tar? You may
> need to use a GNU-compatible one that handles long filenames (over 100
> chars).
bye
Davide
| Re: [Stellation] tar file corrupted [message #576705 is a reply to message #22535] |
Thu, 12 September 2002 05:37  |
>> chars).
-Mark
| Re: [Stellation] tar file corrupted [message #581648 is a reply to message #22535] |
Thu, 12 September 2002 05:39  |
>> chars).
-Mark
| Re: [Stellation] tar file corrupted [message #581768 is a reply to message #23405] |
Fri, 13 September 2002 02:02  |
Alin
> >> chars).
> -Mark
markcc@bestweb.net
| Re: [Stellation] tar file corrupted [message #581808 is a reply to message #23617] |
bewdy,
- jed.
> Alin
may
100
> > >> chars).
> > -Mark
> markcc@bestweb.net
| Re: [Stellation] tar file corrupted [message #581833 is a reply to message #23660] |
something great.
Alin
PVCS
technology
> bewdy,
> - jed.
> > Alin
> may
> 100
> > > >> chars).
> > > -Mark
> > markcc@bestweb.net
| Re: [Stellation] tar file corrupted [message #582032 is a reply to message #23617] |
Fri, 13 September 2002 17:41  |
On Fri, 13 Sep 2002 06:02:32 +0000, Alin wrote:
> I'm curios why Eclipse is still using cvs and not stellation.. Or maybe
Well, the biggest reason is the fact that Stellation isn't even
in beta-test yet. We (the Stellation team) secretly dream of getting
Eclipse to adopt Stellation in place of CVS. But we're a long way from
that point.
-Mark
| Re: [Stellation] tar file corrupted [message #582053 is a reply to message #23660] |
-Mark
Current Time: Fri Nov 21 08:25:50 EST 2025
Powered by FUDForum. Page generated in 0.07605 seconds
