Home » Language IDEs » C / C++ IDE (CDT) » Changing the type of folder
Changing the type of folder [message #227258] Tue, 25 November 2008 14:13 Go to next message
IS it possible to change the type of a folder from forder to source
folder? If a folder is not a sourcefolder I cannot generate a class in it?
TIA
Joost
Re: Changing the type of folder [message #227265 is a reply to message #227258] Wed, 26 November 2008 02:45 Go to previous messageGo to next message
Originally posted by: subs._nospam_consertum.com
Joost Kraaijeveld wrote:
> TIA
> Joost
File->New->Source folder and give it the name of an existing folder.
Derek
Re: Changing the type of folder [message #227301 is a reply to message #227265] Wed, 26 November 2008 13:28 Go to previous messageGo to next message
That seems to work, but now I have 2 folders with the same name and
content in my project...
Strange. Is that by design?
I could get the second (new) one to get away by excluding it from the build.
Joost
Re: Changing the type of folder [message #227338 is a reply to message #227258] Thu, 27 November 2008 05:14 Go to previous messageGo to next message
hmm, not sure if I got you right, but all source folders are listed in the
properties of a project. Open the project properties, browse to the "c/c++
general" / "paths and symbols" section. select the "source location" tab
page, there you'll find all source folders of your project. By clicking on
"add folder", you can select an existing, non-source folder from your
project and transform it to a source folder (the). Hope this helps!
sth_Weird
Re: Changing the type of folder [message #227397 is a reply to message #227338] Fri, 28 November 2008 01:40 Go to previous message
> the properties of a project. Open the project properties, browse to the
> "c/c++ general" / "paths and symbols" section. select the "source
> location" tab page, there you'll find all source folders of your
> project. By clicking on "add folder", you can select an existing,
> non-source folder from your project and transform it to a source folder
It did: now the source folders are source folder again. Thanks
Joost
Previous Topic:regular expression error parser
Next Topic:"Launch failed. Binary not found." question
Current Time: Fri Nov 21 07:46:01 EST 2025
Powered by FUDForum. Page generated in 0.04518 seconds
