Home » Archived » Maven Integration (M2E) » Can't run Maven tests
Can't run Maven tests [message #22104] Wed, 25 February 2009 16:42 Go to next message
Originally posted by: sadsdfd.asds.com
I have made a Maven project, where I have made a test file in a package
in/src/test/java:
package mytestpackage
import static org.junit.Assert.*;
import org.junit.Test;
public class TableTest{
@Test
public void myFirstTest() throws Exception {
assertEquals("asd","asd");
@Test
public void mySecondTest() throws Exception {
assertEquals("asd2","asd2");
But when I right click on the Maven project (parent) and choose:
Run As -> Maven test
The test in not run, and I just get:
[INFO] ------------------------------------------------------------ ------------
[INFO] BUILD SUCCESSFUL
[INFO] Total time: < 1 second
[INFO] Finished at: Wed Feb 25 22:38:21 CET 2009
[INFO] Final Memory: 1M/4M
What do I need to do to enable the maven tests?
Re: Can't run Maven tests [message #22150 is a reply to message #22104] Wed, 25 February 2009 16:51 Go to previous messageGo to next message
try having the test case extend TestCase
then it should be picked up
jesse
> in/src/test/java:
> @Test
> @Test
> [INFO]
> [INFO]
> [INFO]
Re: Can't run Maven tests [message #22193 is a reply to message #22150] Wed, 25 February 2009 16:57 Go to previous messageGo to next message
Extending Test Case does not help.
I have access to another Maven project that uses something called surefire:
[INFO] [surefire:test]
[INFO] Surefire report directory:
C:\Users\js\workspace2\parent\model\target\surefire-reports
I think that might be needed to run a maven test, but cannot make it work on
my new clean project.
"Jesse McConnell" <jesse.mcconnell@gmail.com> wrote in message
news:go4egt$qhb$1@build.eclipse.org...
> jesse
>> in/src/test/java:
>> @Test
>> @Test
Re: Can't run Maven tests [message #22236 is a reply to message #22193] Thu, 26 February 2009 13:25 Go to previous message
Problem solved. Child modules should use 'jar' packaging and NOT 'pom'
packaging.
"JS" <sadsdfd@asds.com> wrote in message
news:go4ert$201$1@build.eclipse.org...
> surefire:
> on my new clean project.
>> jesse
>>> in/src/test/java:
>>> @Test
>>> @Test
Previous Topic:[tycho-dev-1819] error while building jar
Next Topic:M2, Subclipse and multi-module project
Current Time: Wed Nov 12 16:09:06 EST 2025
Powered by FUDForum. Page generated in 0.04199 seconds
