Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » DLTK IDE Guide examples - missing getTextTools?
DLTK IDE Guide examples - missing getTextTools? [message #22099] Mon, 07 April 2008 15:55 Go to next message
I am trying to build the example source files that I downloaded to accompany
the DLTK IDE Guide.
Right now, when I try to build the part 3 project
(org.eclipse.dltk.examples.python.part3), I get the following errors:
Severity and Description Path Resource Location Creation Time Id
The method getTextTools() is undefined for the type ExamplePythonUI
org.eclipse.dltk.examples.python.part3/src/org/eclipse/dltk/ examples/python/internal/ui/editor
ExamplePythonContentAssistPreference.java line 20 1207595417216 100898
ExamplePythonDocumentSetupParticipant.java line 28 1207595417216 100897
ExamplePythonEditor.java line 37 1207595417216 100896
Each of these lines of code looks like this:
ExamplePythonUI.getDefault().getTextTools();
ExamplePythonUI has the implementation of getDefault:
* Returns the shared instance
* @return the shared instance
public static ExamplePythonUI getDefault() {
return plugin;
I'm not sure where this method should be defined.
Chuck
Re: DLTK IDE Guide examples - missing getTextTools? [message #22143 is a reply to message #22099] Tue, 08 April 2008 02:14 Go to previous messageGo to next message
Hi Chuck,
I suppose you just skipped step to define this method it.
You should insert following code to ExamplePythonUI class.
private ExamplePythonTextTools fPythonTextTools;
public synchronized ExamplePythonTextTools getTextTools() {
if (fPythonTextTools == null)
fPythonTextTools= new ExamplePythonTextTools(true);
return fPythonTextTools;
Additional information in tutorial: http://wiki.eclipse.org/DLTK_IDE_Guide:Step_2._Towards_an_Ed itor#Source_configuration
Andrei Sobolev.
> the DLTK IDE Guide.
> return plugin;
> Chuck
Re: DLTK IDE Guide examples - missing getTextTools? [message #22228 is a reply to message #22143] Wed, 09 April 2008 21:06 Go to previous message
Indeed - you are right - I missed that.
That's what happens when I:
a) start to follow the tutorial (which automatically creates the plugin
class)
b) attempt to short circuit the tutorial by copying the downloaded
finished code
(but everything except the default plugin class created
automatically)
Sorry for the false problem report, and thanks for the quick response.
Chuck
"Andrei Sobolev" <haiodo@xored.com> wrote in message
news:ftf2go$ll4$1@build.eclipse.org...
> Hi Chuck,
> Best regards,
> Andrei Sobolev.
>> accompany
>> the DLTK IDE Guide.
>> return plugin;
>> Thanks,
>> Chuck
Previous Topic:Query regarding DLTK JRubySourceParser
Next Topic:Expanding dltk.tcl for java/ctl (jacl)
Current Time: Fri Nov 07 15:29:06 EST 2025
Powered by FUDForum. Page generated in 0.18397 seconds
