Home » Eclipse Projects » Remote Application Platform (RAP) » combo problem
combo problem [message #22092] Fri, 04 May 2007 05:13 Go to next message
Originally posted by: manuel.staechele.levante-software.ch
hi,
have the following app
class x
private Combo a;
private fillCombo
a.add(val1);
private onclick
i = a.getSelectionIndex();
alert(i);
i get ever a return: -1
i test to a.add(val1, i) (i = i++ in a while) but the same
i also can not add random int indexes (a.add(val1, random());) error:
index out of bounds
that is a problem for me because i want to explorer a database table
(e.g country(id, name)) to a combo and inert the value the user selected
in the database)
Re: combo problem [message #22138 is a reply to message #22092] Fri, 04 May 2007 05:27 Go to previous messageGo to next message
Originally posted by: roberto.sanchez.autonomind.com
Hi Manuel, I had a similar problem, method getSelectionIndex() always
returns -1 You can see it here:
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=185039).
I'm not sure if is the same situation, in any case It's possible that
bug comments can help you.
Regards.
Roberto.
Manuel Staechele wrote:
> hi,
> class x
> private Combo a;
> private fillCombo
> a.add(val1);
> private onclick
> alert(i);
> index out of bounds
> in the database)
Re: combo problem [message #22182 is a reply to message #22138] Fri, 04 May 2007 05:51 Go to previous messageGo to next message
thanks Roberto,
a bit uncomfortable solution, but it work ;-)
greetings
manuel
> Regards.
> Roberto.
>> hi,
>> class x
>> private Combo a;
>> private fillCombo
>> a.add(val1);
>> private onclick
>> alert(i);
>> index out of bounds
>> selected in the database)
Re: combo problem [message #22229 is a reply to message #22138] Fri, 04 May 2007 06:29 Go to previous message
>> index out of bounds
i there also a solution available?
otherwise i must get the text, then get the index by the text out of the
table ... little long-winded...
Previous Topic:GWT vs RAP Benchmark
Next Topic:RAP and UI Forms
Current Time: Thu Nov 20 14:14:35 EST 2025
Powered by FUDForum. Page generated in 0.04533 seconds
