Re: Re: [buckminster-dev] Plugin dependencies and cspex file [message #22081] |
Mon, 21 July 2008 10:12 |
Originally posted by: jcampolongo.cra.com
------_=_NextPart_001_01C8EB3B.DCD71268
Content-Type: text/plain;
charset="US-ASCII"
> Hi Joseph,
> Do you put this in a file called buckminster.cspex (note the 'x' at
the=20
> end) in the project root?
> If you right-click on the project and do "Buckminster" - "View=20
> CSpec...", can you see the dependency there?
=20
Yes and Yes, which is why I find it so strange that the dependency isn't
built. I'm using the following versions:
=20
Eclipse
Version: 3.4.0
Build id: I20080617-2000
=20
Buckminster UI
1.1.0r09456
=20
Buckminster Core
1.1.0r09453
=20
Joseph Campolongo
=20
=20
=20
=20
THIS MESSAGE IS INTENDED FOR THE USE OF THE PERSON TO WHOM IT IS =
ADDRESSED. IT MAY CONTAIN INFORMATION THAT IS PRIVILEGED, CONFIDENTIAL =
AND EXEMPT FROM DISCLOSURE UNDER APPLICABLE LAW. If you are not the =
intended recipient, your use of this message for any purpose is strictly =
prohibited. If you have received this communication in error, please =
delete the message and notify the sender so that we may correct our =
records.
Content-Type: text/html;
charset="US-ASCII"
<HTML >
<HEAD>
<META http-equiv=3D"Content-Type" content=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 11 (filtered medium)">
<style>
/* Font Definitions */
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
font-family:Arial;
color:windowtext;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
</style>
</HEAD>
<BODY lang=3DEN-US link=3Dblue vlink=3Dpurple>
<DIV>
<DIV>
<div class=3DSection1>
<p class=3DMsoNormal style=3D'text-autospace:none'><font size=3D2 =
face=3D"Courier New"><span
style=3D'font-size:10.0pt;font-family:"Courier New"'>> Hi =
Joseph,<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier New"'>> Do you put =
this in a
file called buckminster.cspex (note the 'x' at the =
style=3D'font-size:10.0pt;font-family:"Courier New"'>> end) in the =
project
root?<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier New"'>> If you =
right-click on
the project and do "Buckminster" - "View =
style=3D'font-size:10.0pt;font-family:"Courier New"'>> =
CSpec...", can you
see the dependency there?<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier =
New"'><o:p> </o:p></span></font></p>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'>Yes and Yes, which is why I find it so strange that the =
dependency isn’t
built. I’m using the following =
versions:<o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
style=3D'font-size:
12.0pt'>Eclipse<o:p></o:p></span></font></p>
<p class=3DMsoNormal style=3D'text-autospace:none'><font size=3D1 =
face=3DTahoma><span
style=3D'font-size:8.0pt;font-family:Tahoma'>Version: =
3.4.0<o:p></o:p></span></font></p>
face=3DTahoma><span
style=3D'font-size:8.0pt;font-family:Tahoma'>Build id: =
I20080617-2000<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
12.0pt'>Buckminster UI<o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt'>1.1.0r09456<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
12.0pt'>Buckminster Core<o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt'>1.1.0r09453<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
12.0pt'>Joseph Campolongo<o:p></o:p></span></font></p>
</div>
</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV STYLE=3D"FONT-SIZE: 9pt; FONT-FAMILY: Courier New">
<FONT FACE=3D"Arial" SIZE=3D"1">THIS MESSAGE IS INTENDED FOR THE USE OF =
THE PERSON TO WHOM IT IS ADDRESSED. IT MAY CONTAIN INFORMATION THAT IS =
PRIVILEGED, CONFIDENTIAL AND EXEMPT FROM DISCLOSURE UNDER APPLICABLE =
LAW. If you are not the intended recipient, your use of this message for =
any purpose is strictly prohibited. If you have received this =
communication in error, please delete the message and notify the sender =
so that we may correct our records.</FONT>
</DIV>
<DIV STYLE=3D"FONT-SIZE: 9pt; FONT-FAMILY: Courier New"> </DIV>
<DIV STYLE=3D"FONT-SIZE: 9pt; FONT-FAMILY: Courier New"></DIV>
</DIV></BODY></HTML>
------_=_NextPart_001_01C8EB3B.DCD71268--
FUDForum. Page generated in 0.03219 seconds
