Home » Modeling » OCL » Re: integrating ocl with emf
Re: integrating ocl with emf [message #22053] Wed, 09 May 2007 07:00 Go to next message
Aashu,
I'm forwarding your question to the OCL newsgroup by adding it to the
"to" list in the reply. Please use that newsgroup for asking OCL in the
future.
aashu aggarwal wrote:
> i m trying to integrate my emf model with ocl
> in validator class functions defined in ecore are getting created
> my code is:
> OCLExpression oclExpr=null;
> <b>IOCLHelper helper=HelperUtil.createOCLHelper()</b>
> helper.setContext(EmployeePackage.Literals.EMPLOYEE);
> when the highlighted line is executed program exits
> can anyone help me ?
> what is the reason for this?
> TIA
> aashu
Re: integrating ocl with emf [message #22272 is a reply to message #22053] Wed, 09 May 2007 08:34 Go to previous message
Hi, Aashu,
What do you mean by "program exits"? Are you running in an Eclipse
instance, or stand-alone? Do you see any exception in the Eclipse log?
(or, if stand-alone, a stack trace on the console?)
Without any diagnostic information, I won't be able to help much. I can't
think of a good reason why that statement should cause a stable JVM
implementation to abort, even if (for example) a class couldn't be loaded.
Christian
Ed Merks wrote:
> Aashu,
> future.
>> my code is:
>> TIA
>> aashu
Previous Topic:error in creating expression using EMF enumeration
Next Topic:Invariant disallowing element usage
Current Time: Fri Nov 21 16:07:12 EST 2025
Powered by FUDForum. Page generated in 0.03494 seconds
