| newbie can't get started [message #226037] |
Sat, 10 April 2004 20:39  |
I just downloaded vM8 for Windows (XP), but I can't get the app to start.
When I double click it, a log message generates with the following in it:
!SESSION ------------------------------------------------------------ -------
!ENTRY org.eclipse.core.launcher 4 0 Apr 10, 2004 20:12:27.437
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.NoSuchMethodError
org.eclipse.osgi.framework.util.SecureAction.getFileOutputSt ream(SecureActio
n.java:102)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultLo g.openFile(Defau
ltLog.java:106)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultLo g.log(DefaultLog
..java:146)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:125)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:267)
at org.eclipse.core.launcher.Main.run(Main.java:692)
at org.eclipse.core.launcher.Main.main(Main.java:676)
I also tried setting the vm by the command prompt as per the eclipse faq,
but entering both 'eclipse.exe -vm c:\program
files\java\j2re1.4.2_04\bin\javaw.exe' or '
eclipse.exe -vm C:\Program Files\Java\Sun\AppServer\jdk\bin\javaw.exe '
earns me a dialog saying that "no Java virtual machine could be found at the
Just to make sure, I checked add/remove programs and saw that both the
1.4.2_04 jre and 1.4.2_02 sdk were listed there.
Any help much appreciated.
Thanks in advance
- Eric
FUDForum. Page generated in 0.03686 seconds
