Can't run Eclipse under RH9 [message #225893] |
Sat, 10 April 2004 13:33  |
Originally posted by: bud.curtis.direcway.com
I just downloaded the Eclipse ZIP for Linux-Motif and installed it under
the /opt folder. I did this under root and I'm trying to run it as root
for the moment. There appears to be a disconnect either in a
configuration or the java VM. When I run Eclipse I get the following:
[root@Hercules root]# cd /opt/eclipse
[root@Hercules eclipse]# ./eclipse
Warning: -os not understood. Ignoring.
Warning: -ws not understood. Ignoring.
Warning: -arch not understood. Ignoring.
Warning: -showsplash not understood. Ignoring.
Also, I get a popup message saying I should look into my .metadata
folder under the user for an explanation of what is wrong. However,
there is no .metadata folder unless I create one, and when I create one
nothing is put into it. Since I installed it as root, running as root,
I don't think I'm dealing with a permissions issue.
Just another data point, when I run java in the eclipse folder to get
its version, I get the following:
[root@Hercules eclipse]# java -version
java version "1.3.1"
jdkgcj 0.2.3 (http://www.arklinux.org/projects/jdkgcj)
gcj (GCC) 3.2.2 20030222 (Red Hat Linux 3.2.2-5)
Copyright (C) 2002 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
It really bothers me that the SUN installed java is reporting 1.3.1, but
I'm certain I installed the 1.4.2 bin file. When I start the install
bin I get a window with the following message:
The InstallShield Wizard will install Java 2 Platform, Standard
Edition, v1.4.2 and NetBeans IDE 3.5.1 on your computer.
By the way, the installed NetBeans runs fine that came with the java VM.
There could almost be a conspiracy here! Any pointers or help would
be appreciated.
Bud Curtis
Re: Can't run Eclipse under RH9 [message #225970 is a reply to message #225893] |
Sat, 10 April 2004 19:16   |
I figured it out thanks to Dan Gray's input. Evidently Red Hat 9 has a 3.2
version of java installed in the /usr/bin. If you don't put the newer java
SDK 1.4.2 in the front of the path, Eclipse can't come up. Now that I have
it in the Eclipse is coming up fine.
Bud Curtis
Colorado Springs, CO
"Bud Curtis" <bud.curtis@direcway.com> wrote in message
news:c59e7v$4qf$1@eclipse.org...
PURPOSE.
> be appreciated.
> Bud Curtis
Re: Can't run Eclipse under RH9 [message #226119 is a reply to message #225970] |
Sun, 11 April 2004 04:11  |
Actually, that's looks like the runtime for the GNU Compiler for
Java, which compiles Java bytecodes into natively executable
form. The Eclipse launcher, "eclipse", has a -vm parameter to
let you specify the exact "java" executable to use.
FUDForum. Page generated in 0.05112 seconds
