Home » Eclipse Projects » Eclipse Platform » View full filenames of opened java files
View full filenames of opened java files [message #22017] Tue, 29 April 2003 08:47 Go to next message
Originally posted by: bewalther.tiscalinet.ch
When having multiple java source files opened in the java editor, the
filenames get cuttet(diplaying e.g. MyN.... instead MyNewHouse.java), and
it gets quite difficult to navigate between them. Can you configure this
view to see the full file names?
Thanks a lot
Re: View full filenames of opened java files [message #22279 is a reply to message #22017] Tue, 29 April 2003 10:16 Go to previous message
Originally posted by: bdeweese.yahoo.com
Hey, finally one I can answer. Edit the
ECLIPSE_DIR\plugins\org.eclipse.platform_2.1.0\plugin_custom ization.ini
file and add the following lines. These options were in some 2.1 beta
releases but weren't considered ready for prime time for 2.1 so were
removed.
# EditorList Pulldown - activate by setting to true.
org.eclipse.ui.workbench/EDITORLIST_PULLDOWN_ACTIVE=true
# TabCompression - specify the amount of compression to use on the
# editor tabs. The value is multiplied by the font height and used as
# the maximum width of the tab. So a smaller number will compress more.
# Use a large number, such as 30, to turn off tab compression.
# Typical values are: high=3, medium=6, low=9, none=30
org.eclipse.ui.workbench/EDITOR_TAB_WIDTH=8
Ben wrote:
> Thanks a lot
Previous Topic:Modification Timesstamp change in the complete project. Why ?
Next Topic:Adding an external build tool
Current Time: Sat Aug 02 16:54:31 EDT 2025
Powered by FUDForum. Page generated in 0.03446 seconds
