Home » Eclipse Projects » Eclipse Platform » Rung a Swing Application as a plugin.
Rung a Swing Application as a plugin. [message #225706] Sat, 10 April 2004 01:08
Originally posted by: rajiv_im.yahoo.com
I am new to the eclipse plugin development area and am trying to run the
swing based Sun Bean Development kit as a plugin in
eclipse.
Currently I am looking at running the software as a plugin independent of
the workbench .. viz. as a plugin that would pop-up swing based windows
inside eclipse. ( .. not using SWT at all ).
The application has 4 separate java.awt.Panel windows. The first panels
load properly .. but when the 2nd java.awt.Panel is to load it hands over
the control to the org.eclipse.swt.widgets.EventTable and throws the
folowing error on the console ..
Unhandled exception caught in event loop.
Reason:
javax/infobus/InfoBusDataController
Could someone pls help me with this problem ? Can we run as a plugin an awt
application that uses multiple windows inside Eclipse or are there known
issues for doing these ?
Rajiv
Previous Topic:How to add DirectoryDialog to InstallHandler Classpath?
Next Topic:Rebuild project in 3.0M8 (linux gtk)
Current Time: Wed Nov 05 21:46:34 EST 2025
Powered by FUDForum. Page generated in 0.06194 seconds
