Home » Eclipse Projects » GEF » Suppress PropertySheet Undo/Redo
Suppress PropertySheet Undo/Redo [message #225657] Wed, 01 November 2006 09:18 Go to next message
is there any way to suppress the undo/redo functionality the property sheet provides?
I have several properties of model elements in my GEF editor that can be edited through the property sheet. The setPropertyValue method of my PropertySources calls GEF commands, which change the properties in the model and provide the undo/redo functionality, so I don't need (and don't want, because the change of properties is too complex) the undo/redo funcionality the PropertySheet creates. Is there any way I could realize this?
Thanks for your help,
Christian
Re: Suppress PropertySheet Undo/Redo [message #225850 is a reply to message #225657] Thu, 02 November 2006 15:36 Go to previous messageGo to next message
Hi Christian,
How are you executing the GEF command? Through the command stack, i.e.
something like getDomain().getCommandStack().execute(myCommand)? If yes,
for not being able to undo/redo this command don't execute the command
through the command stack. From setPropertyValue method it should be safe
just to call myCommand.execute().
A workaround is to do all changes to the model inside setPropertyValue
without using GEF commands.
Alex
Re: Suppress PropertySheet Undo/Redo [message #226010 is a reply to message #225850] Sat, 04 November 2006 06:14 Go to previous messageGo to next message
I'm executing the command through the command stack, because that is what I actually want, that my own undo/redo from the GEF command is used. I don't want the undo/redo from the setPropertyValue method to be used(that's why I don't do the changes in the model directly in the setPropertyValue method), because the generated undo/redo is too dumb and does not what it should.
Christian
Re: Suppress PropertySheet Undo/Redo [message #226125 is a reply to message #225657] Mon, 06 November 2006 01:22 Go to previous message
Originally posted by: none.unknown.com
Don't use UndoablePropertySheetEntry. Override
GraphicalEditor#getAdapter().
"Christian Seitz" <chr.seitz@gmx.de> wrote in message
news:22240347.1162390761635.JavaMail.root@cp1.javalobby.org...
> sheet provides?
> this?
> Christian
Previous Topic:How to implement Container and Layout Policy
Next Topic:Context Menu Provider
Current Time: Sat Nov 01 09:32:04 EDT 2025
Powered by FUDForum. Page generated in 0.04193 seconds
