Home » Eclipse Projects » Eclipse Platform » Use Eclipse preferences
Use Eclipse preferences [message #224658] Thu, 08 April 2004 12:03 Go to next message
I want to save information on a per user basis to their workspace. I have
heard about Eclipse preferences. Is this something that can be used for
this?
What is the API called for using Eclipse preferences?
Thank you,
Re: Use Eclipse preferences [message #224681 is a reply to message #224658] Thu, 08 April 2004 12:28 Go to previous messageGo to next message
Originally posted by: dj_houghton.nospam.ca.ibm.com
What do you mean by per user for their workspace? Are multiple users
sharing the same workspace?
There is new API in org.eclipse.core.runtime.preferences.
> this?
> Thank you,
Re: Use Eclipse preferences [message #224690 is a reply to message #224681] Thu, 08 April 2004 12:29 Go to previous messageGo to next message
I just meant that I want to save values in the users workspace.
So, when they start up their workspace I can retrieve this value.
> > this?
> > Thank you,
Re: Use Eclipse preferences [message #224851 is a reply to message #224690] Thu, 08 April 2004 16:07 Go to previous messageGo to next message
If you are creating preference pages then check out
Plugin.getPluginPreferences(). If you browse for references to this
method you will see lots of references in the Platform.
The package that I mention below is the "new way". We are hoping that
the preference page mechanism will be hooked directly into the new APIs
post 3.0. (they are hooked into them via a backwards compatibility layer
currently)
>>>this?
>>>Thank you,
Re: Use Eclipse preferences [message #226094 is a reply to message #224658] Sun, 11 April 2004 03:14 Go to previous message
Hi Greg,
There are a couple of articles on the Eclipse web site covering this. Start with:
http://www.eclipse.org/articles/Article-Preferences/preferen ces.htm
and then check out
http://www.eclipse.org/articles/index.html
for other articles with "Preferences" in the title. The others seem to be mostly
to do with the UI side of things.
Yours,
Ian.
#ifndef __COMMON_SENSE__ | Ian Phillips
#include <std_disclaimer> | TIBCO Software Inc.
#endif | www.tibco.com
Previous Topic:newbie can't get started
Next Topic:Can't run Eclipse under RH9
Current Time: Mon Dec 01 21:58:56 EST 2025
Powered by FUDForum. Page generated in 0.04150 seconds
