Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Signature change for IBuildpathContainer.getBuildpathEntries()
| Signature change for IBuildpathContainer.getBuildpathEntries() [message #21829] |
Mon, 31 March 2008 17:35  |
All,
Why has IBuildpathContainer.getBuildpathEntries() been overloaded to expect
a parameter of IScriptProject? Also, why was the original, no-parameter
version retained rather than removed, since DLTK is still in beta?
Are IBuildpathContainer instances expected to be reusable across projects
now? If so, why don't the other methods accept an IScriptProject as well?
Thank You,
Shelby Sanders
| Re: Signature change for IBuildpathContainer.getBuildpathEntries() [message #21873 is a reply to message #21829] |
Tue, 01 April 2008 01:12   |
Hi Shelby,
This allows per project customization of interpreter container, via org.eclipse.dltk.core.interpreterContainerExtension
extension point.
For example for tcl project in interpreter container entry we hold list of tcl package names, used in project. So each
project could contain different set of interpreter libraries.
You are right, I've removed old method. Thanks.
No they are not expected to be reusable.
Andrei Sobolev.
| Re: Signature change for IBuildpathContainer.getBuildpathEntries() [message #21918 is a reply to message #21873] |
Tue, 01 April 2008 12:57   |
What about the other methods?
I would expect at least getDescription() and getBuiltinProvider() to have
respective output based on the associated project as well.
> Hi Shelby,
> extension point.
> Best regards,
> Andrei Sobolev.
Thank You,
Shelby Sanders
| Re: Signature change for IBuildpathContainer.getBuildpathEntries() [message #22011 is a reply to message #21918] |
Wed, 02 April 2008 05:51   |
Hi Shelby,
Sure. I've added parameter to this methods.
Andrei Sobolev.
>> Hi Shelby,
>> extension point.
>> Best regards,
>> Andrei Sobolev.
> Thank You,
> Shelby Sanders
| Re: Signature change for IBuildpathContainer.getBuildpathEntries() [message #22055 is a reply to message #22011] |
Wed, 02 April 2008 13:03  |
Cool. Thanks, Andrei.
> Hi Shelby,
> Best regards,
> Andrei Sobolev.
>>> Hi Shelby,
>>> extension point.
>>> tcl
>>> Best regards,
>>> Andrei Sobolev.
>> Thank You,
>> Shelby Sanders
Thank You,
Shelby Sanders
Current Time: Sat Nov 22 11:24:38 EST 2025
Powered by FUDForum. Page generated in 0.17426 seconds
