Home » Newcomers » Newcomers » how i do develope a property dialog
how i do develope a property dialog [message #224056] Fri, 27 July 2007 03:14 Go to next message
Originally posted by: caye5200.yahoo.com.cn
hi , i am VE new developer. now i want devloper a property dialog
int property sheet.
i am developed a property dialog with "java.lang.Integer"
property ,eg
First i create a override file , the property is "ailgnment",
Following
<objectsToAttach xmi:id="_eStructuralFeatures" name="alignment"
unsettable="true" xsi:type="ecore:EReference">
<eAnnotations
cellEditorClassname=" com.hitachi.yokohama.dtv/com.hitachi.yokohama.dtv.editor.HLe ditor "
xsi:type=" org.eclipse.ve.internal.cde.decorators:BasePropertyDecorator "/>
</objectsToAttach>
Second i develop a Hleditror class ,Following
public class HLeditor extends DialogCellEditor implements INeedData
public HLeditor(Composite aComposite) {
super(aComposite);
//create a IJavaInstance
private static IJavaInstance createIntJavaObject(int aInt,int type)
String pos=pakage;
switch(aInt)
case 0:
switch(type)
case 0:
pos=pos+"HiLabel.LEFT";break;
case 1:
pos=pos+"HiLabel.FREE,10";break;
};break;
case 1:
pos=pos+"HiLabel.CENTER";break;
case 2:
pos=pos+"HiLabel.RIGHT"; break;
return BeanUtilities.createJavaObject(
"java.lang.Integer",
JavaEditDomainHelper.getResourceSet(fEditDomain),
BeanPropertyDescriptorAdapter.createAllocation(pos
,fEditDomain));
/* (non-Javadoc)
* @see
org.eclipse.jface.viewers.DialogCellEditor#openDialogBox(org .eclipse.swt.widgets.Control)
protected Object openDialogBox(Control cellEditorWindow) {
if (dialog.open() != Window.CANCEL) {
return createIntJavaObject(this.postion,this.flag);
} else { return getValue();
/* (non-Javadoc)
* @see
org.eclipse.ve.internal.propertysheet.INeedData#setData(java .lang.Object)
public void setData(Object data) {
fEditDomain = (EditDomain) data;
// A int instance varialble is created to store the value of that
property
protected void doSetValue(Object value) {
if (value != null){
INumberBeanProxy intBeanProxy = (INumberBeanProxy)
BeanProxyUtilities.getBeanProxy((IJavaInstance) value);
intValue=intBeanProxy.intValue();
super.doSetValue(value);
//update Data
protected void updateContents(Object value) {
super.updateContents(Integer.valueOf(intValue));
Now hava two propertis "text" and "alignment" the set Methods are
setText(String[] args)
and setAlignment(int alignment ,int x)
the types how set? i try set "java.lang.Object" but
the view have error.
eg following
private IJavaInstance createStringJavaObject(String initString ) {
return BeanUtilities.createJavaObject("java.lang.Object",
initString);
the code can genrated but the view have exception,Please tell me
,how can i do? thank you.
zhaoxc &#65288; come
from china &#65289;
Re: how i do develope a property dialog [message #224113 is a reply to message #224056] Fri, 27 July 2007 09:25 Go to previous message
--------------090608050303070507020002
You'd likely be best off to ask on the VE newsgroup:
<news://news.eclipse.org/eclipse.tools.ve>
I would suggest including a stack trace in your question.
> int property sheet.
> property ,eg
> Following
> <eAnnotations
> </objectsToAttach> ..........................
> super(aComposite);
> String pos=pakage;
> switch(aInt)
> case 0:
> switch(type)
> case 0:
> case 1:
> };break;
> case 1:
> case 2:
> ,fEditDomain)); }
> /* (non-Javadoc)
> * @see
> /* (non-Javadoc)
> * @see
> property
> if (value != null){
> //update Data
> eg following
> initString);
> zhaoxc &#65288;
> come
> from china &#65289;
<html>
<head>
http-equiv="Content-Type">
</head>
You'd likely be best off to ask on the VE newsgroup:<a
href="news://news.eclipse.org/eclipse.tools.ve"><br>
</a>
<blockquote><a href="news://news.eclipse.org/eclipse.tools.ve">news://news.eclipse.org/eclipse.tools.ve</a><br>
</blockquote>
I would suggest including a stack trace in your question.<br>
<br>
<br>
zhaoxc wrote:
<blockquote
cite="mid:f212445f22956027e742e751f059de60$1@www.eclipse.org"
type="cite">hi , i am
Previous Topic:CDT Not working
Next Topic:Visual editor
Current Time: Fri Nov 28 11:11:18 EST 2025
Powered by FUDForum. Page generated in 0.09906 seconds
