Home » Archived » IAM (Eclipse Integration for Apache Maven) » Installation timeout in Galileo
Installation timeout in Galileo [message #21798] Wed, 15 July 2009 06:05 Go to next message
i tried to install iam on a newly downloaded fresh Galileo platform.
After a few minutes that eclipse tries to figure out the content it throws
an error message that says :
Communication with repository at
http://q4e.googlecode.com/svn/trunk/updatesite-iam/site.xml failed.
Read timed out
I would appreciate every help on that.
thanks
chilber
Re: Installation timeout in Galileo [message #21845 is a reply to message #21798] Wed, 15 July 2009 19:57 Go to previous message
I have been able to access the url without any problems. Maybe there was
some maintenance going on when you tried?
Please check that you can access the url from a browser and try again.
If it still does not work, verify your eclipse proxy settings (just in
case).
Let us know if you are able to install IAM.
chilber wrote:
> throws an error message that says :
> Read timed out
> thanks chilber
Abel Muiño
Re: Installation timeout in Galileo [message #570239 is a reply to message #21798] Wed, 15 July 2009 19:57 Go to previous message
case).
chilber wrote:
> Read timed out
> thanks chilber
Abel Muiño
Previous Topic:Installation timeout in Galileo
Next Topic:eclipse 3.5 iam 0.10.0 No providers found matching selection: default
Current Time: Tue Nov 25 18:34:36 EST 2025
Powered by FUDForum. Page generated in 0.04264 seconds
