Home » Eclipse Projects » Nebula » To change the color of the image in the cell
To change the color of the image in the cell [message #21749] Tue, 02 January 2007 23:55 Go to next message
Originally posted by: krishna_24jan.yahoomail.com
Iam adding an image in a grid item by using griditem.setImage.
Now i want to change the color of the image with out changing the image.
Iam trying to use gridItem.setForeground but its not working.
Can i dynamically draw the image in the cell.Imean if i want a round image
can i dynamically draw in the code with out statically placing the image..?
or any other suggestions to sove my problem..?
Thanks in advance
krishna
Re: To change the color of the image in the cell [message #22019 is a reply to message #21749] Thu, 04 January 2007 11:26 Go to previous messageGo to next message
The Grid will not alter the image for you. You can create your own
image and then set it to the item. For example:
Image image = new Image(display,16,16);
GC gc = new GC(image);
//draw stuff
gc.dispose();
gridItem.setImage(2,image);
-Chris
krishna wrote:
> image can i dynamically draw in the code with out statically placing the
> image..?
> Thanks in advance
> krishna
Re: To change the color of the image in the cell [message #29063 is a reply to message #21749] Tue, 13 February 2007 13:03 Go to previous message
you have to create the image with the different color on your own.
BR,
surya.
krishna wrote:
> the image..?
> Thanks in advance
> krishna
Re: To change the color of the image in the cell [message #573872 is a reply to message #21749] Thu, 04 January 2007 11:26 Go to previous message
//draw stuff
gc.dispose();
-Chris
krishna wrote:
> image..?
> Thanks in advance
> krishna
Re: To change the color of the image in the cell [message #578500 is a reply to message #21749] Tue, 13 February 2007 13:03 Go to previous message
BR,
surya.
krishna wrote:
> the image..?
> Thanks in advance
> krishna
Previous Topic:Maximize problem
Next Topic:[CompositeTable] Header and row control construction
Current Time: Thu Nov 06 14:19:18 EST 2025
Powered by FUDForum. Page generated in 0.06088 seconds
