Home » Language IDEs » ServerTools (WTP) » debugging question
debugging question [message #21722] Mon, 10 May 2004 09:59 Go to next message
Originally posted by: ewald.geschwinde.net
I want to debug jspfiles with the debugger such as with Netbeans.
I tried the sysdeo plugin but this does not have this result.
I use eclipse3M8.
Does anyone know of a goog jsp debugging plugin?
Regards Ewald Geschwinde
Re: debugging question [message #22040 is a reply to message #21722] Mon, 10 May 2004 16:05 Go to previous messageGo to next message
Originally posted by: christophe.ney.objectweb.org
If you are looking for an open source one, the one in the Lomboz plug-in may
fit your need.
It is available at http://lomboz.objectweb.org
Christophe
ObjectWeb
"Ewald Geschwinde" <ewald@geschwinde.net> a
Re: debugging question [message #22216 is a reply to message #22040] Tue, 11 May 2004 04:05 Go to previous messageGo to next message
Maybe I have overseen something but I cannot set breakpoints
in jsp files.
And that is what I want.
I'm using this plugin for development but it's lacking debugging features.
Maybe I'm wrong.
I'm here to learn :)
Ewald
Am Mon, 10 May 2004 22:05:13 +0200 schrieb Christophe Ney:
> fit your need.
> Christophe
> ObjectWeb
> "Ewald Geschwinde" <ewald@geschwinde.net> a écrit dans le message news:
> pan.2004.05.10.13.59.13.657987@geschwinde.net...
>> I use eclipse3M8.
Re: debugging question [message #22292 is a reply to message #22216] Tue, 11 May 2004 09:35 Go to previous message
Originally posted by: scott.anderson.genuitec.com
Ewald,
MyEclipse Enterprise Workbench provides source-level debuggin in JSP files
when using a JSR-045 compliant server. You can try it out at
http://www.myeclipseide.com.
"Ewald Geschwinde" <ewald@geschwinde.net> wrote in message
news:pan.2004.05.11.08.05.02.979853@geschwinde.net...
> in jsp files.
> Maybe I'm wrong.
> Ewald
may
> > fit your need.
> > Thanks,
> > Christophe
> > ObjectWeb
Previous Topic:Visual JSP editing
Next Topic:Rich Internet Application
Current Time: Sat Nov 08 14:29:56 EST 2025
Powered by FUDForum. Page generated in 0.03509 seconds
