Home » Eclipse Projects » Buckminster dev » [buckminster-dev] Hello XML World Example error
[buckminster-dev] Hello XML World Example error [message #21717] Sun, 20 July 2008 16:40 Go to next message
Originally posted by: mojo.sebald.t-online.de
Hello there,
I just tried to run the example
( http://www.eclipse.org/buckminster/samples/queries/buckminst er-dev.cquery)
out of eclipse (Version 3.4)
by clicking "Resolve and Materialize" and got the errors:
ERROR [0001] : No suitable provider for component
org.demo.hello.xml.world:osgi.bundle was found in searchPath default
ERROR [0001] : Resolution attempt ended with exception:
org.xml.sax.SAXParseException: Element dateCreated does not represent a
valid RFC822 formatted date:
http://dev.eclipse.org/svnroot/tools/org.eclipse.buckminster /trunk/org.eclipse.buckminster/demo/org.demo.hello.xml.world ,demo.opml
at line: 5 column: 59
Buckminster UI Plug-in Version is 1.1.0.r09456
Any help is welcome.
So long
Johannes
View this message in context: http://www.nabble.com/Hello-XML-World-Example-error-tp185569 79p18556979.html
Sent from the Eclipse - Buckminster Dev mailing list archive at Nabble.com.
Re: [buckminster-dev] Hello XML World Example error [message #21764 is a reply to message #21717] Mon, 21 July 2008 03:14 Go to previous message
Hi Johannes,
Johannes Sebald wrote:
> Hello there,
Are you sure this is the cquery you tried? It seems to me you must have
run: http://www.eclipse.org/buckminster/samples/queries/demo.cque ry
I tried running the demo using the same revision but I'm unable to
reproduce the problem. The OPML is parsed correctly.
What kind of environment are you using? In particular, what Java VM is
in use (vendor and version)?
Thomas Hallgren
Previous Topic:Other actors proposal
Next Topic:[buckminster-dev] Vote for Committer status for Adrian Skehill has started
Current Time: Sun Jul 27 01:18:14 EDT 2025
Powered by FUDForum. Page generated in 0.04033 seconds
