Home » Eclipse Projects » Eclipse Platform » Layouts for adding Views to the workbench
Layouts for adding Views to the workbench [message #222858] Tue, 06 April 2004 10:30 Go to next message
Originally posted by: news.vadalus.com
Hi All,
Is there anyway of changing the layout manager which determines how the
views are layed out in the workbench? I would like to have some
fixed-size views which react to resize events more like a flow layout.
Is it possible to have a view which contains other views?
Is it possible to have multiple instances of the same view class? (with
names determined at run time?)
Many Thanks
Re: Layouts for adding Views to the workbench [message #223118 is a reply to message #222858] Tue, 06 April 2004 16:33 Go to previous messageGo to next message
Originally posted by: eclipse.rizzoweb.com
Vadalus wrote:
> Hi All,
I'm pretty sure I've seen each of these raised in Bugzilla at some
point. The second one is at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=38543 (I know that one
because I reported it ;-)
Try searching the bugs to find the appropriate reports - if you can't,
create your own feature request(s).
HTH,
Eric
Knowledge is a process of piling up facts; wisdom lies in their
simplification.
- Martin H. Fischer
Re: Layouts for adding Views to the workbench [message #238074 is a reply to message #222858] Mon, 03 May 2004 14:58 Go to previous message
Originally posted by: sxenos.__DELETEME__ca.ibm.com
There is no way to change the layout manager for views or to create
recursive views. However, there has been some discussion about adding
these as RCP features in the (distant) future.
What exact behavior are you trying to produce with fixed-size views?
Eclipse 3.0 allows multiple instances of the same view class.
- Stefan
Vadalus wrote:
> Hi All,
> Many Thanks
Previous Topic:ISaveablePart and close events
Next Topic:GEF editor does not work properly after the workbench is mirrored
Current Time: Sun Nov 23 13:21:31 EST 2025
Powered by FUDForum. Page generated in 0.03077 seconds
