Home » Language IDEs » Java Development Tools (JDT) » Possible bug: Deprecated warning in deprecated class
Possible bug: Deprecated warning in deprecated class [message #222458] Thu, 19 January 2006 00:18 Go to next message
1. Using M4, create a Java file, and use a deprecated class (IDOMNode
for example)
=> Both the import and the line that uses the class should have the
deprecation warning
2. Deprecate the class you've just created
=> The import has the deprecation warning
I would expect the warning at the import to go away as well so that the
Java file itself was not "yellow" marked.
Is this a bug?
Marcelo
Re: Possible bug: Deprecated warning in deprecated class [message #222476 is a reply to message #222458] Thu, 19 January 2006 11:37 Go to previous messageGo to next message
Originally posted by: olivier_thomann.NOca.ibm.comSPAM
> for example)
> deprecation warning
> Is this a bug?
yes and no :-).
The scope of the deprecation on the type doesn't enclose the import
statements. Imports belongs to the unit, not to the type.
This might be the same issue than
https://bugs.eclipse.org/bugs/show_bug.cgi?id=123522.
Olivier
Re: Possible bug: Deprecated warning in deprecated class [message #222482 is a reply to message #222476] Thu, 19 January 2006 12:37 Go to previous message
Thx for the bugzilla pointer. It does seem to be related so I've added
this scenario to it.
>> for example)
>> deprecation warning
>> the Java file itself was not "yellow" marked.
>> Is this a bug?
> yes and no :-).
> Olivier
Previous Topic:How to attach source to binary automatically
Next Topic:Change Eclipse Memory on Mac OS 10.4.4
Current Time: Fri Oct 24 22:45:26 EDT 2025
Powered by FUDForum. Page generated in 0.07090 seconds
