small problem with completion [message #222144] |
Wed, 18 July 2007 09:12  |
Originally posted by: charles.prevot.ago.fr
whenever I hit ctrl+space to display the code completion box, every
proposition is displayed twice. For example, if my class Foo has only
one method called bar(), the completion list will display:
bar() Foo-Foo
bar() Foo-Foo
Not a very important bug but quite annoying... Does someone has any idea
where it could come from ?
Re: small problem with completion [message #222866 is a reply to message #222286] |
Thu, 19 July 2007 20:58  |
Originally posted by: eclipse5.rizzoweb.com
Charles Prevot wrote:
> Charles Prevot a écrit :
>>>> Hello,
>>>> only one method called bar(), the completion list will display:
>>>> bar() Foo-Foo
>>>> bar() Foo-Foo
>>>> idea where it could come from ?
>>> Whatever project or JAR that contains those classes in on the build
>>> path twice. Check the Java Build Path of the project you're working
>>> in and eliminate any duplications.
>>> Hope this helps,
>>> Eric
>> thanks for the tip but my problem was the CLASSPATH environment
>> variable that was defined in Windows. I removed it and now everything
>> works fine.
> In fact it worked only at the startup of eclipse. the problem comes from
> mylin (see other msg in thread).
FYI, Eclipse does not use the system CLASSPATH variable at all, so that
was never part of your problem.
Eric
FUDForum. Page generated in 0.07249 seconds
