Home » Eclipse Projects » Eclipse Platform » How to close the editor if it is open when the file is deleted programmatically?
How to close the editor if it is open when the file is deleted programmatically? [message #222066] Mon, 05 April 2004 12:20
Originally posted by: crscca.bol.net.in
Hi guys,
I have posted this same message previously too and didnt get any reply. I
hope someone does reply this time.
When I delete a code file using the following code from my plugin how can
I check whether the code is lying open in a editor and accordingly also
close the editor?
ICompilationUnit cu = packageFragment.getCompilationUnit(
"SomeCode.java");
if (cu.exists())
cu.delete(true, monitor);
Thanks.
P.S.: In case you can recogonize this folowing code I think need its
opposite functionality
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
IDE.openEditor(page, file, true);
Previous Topic:Problem installing an Eclipse plugin (plugin1080722447937.xml)
Next Topic:servlet issue
Current Time: Thu Jul 10 06:21:25 EDT 2025
Powered by FUDForum. Page generated in 0.06189 seconds
