Home » Newcomers » Newcomers » SSL under IDE problem
SSL under IDE problem [message #21623] Mon, 31 January 2005 12:53
Got a strange behavior trying to debug or launch SSL program under eclipse.
Say, I have something as simple as:
URL url = new URL("https://www.verisign.com");
BufferedReader in = new BufferedReader(
new
InputStreamReader(url.openConnection().getInputStream()));
String line = null;
while ((line = in.readLine()) != null) {
System.out.println(line);
Can post the whole if need. Under the eclipse it throws:
Caused by: java.security.NoSuchAlgorithmException: Cannot find any provider
supporting RSA/ECB/PKCS1Padding
What is most strange, it WORKS being launched from command line. I have
rechecked that in both cases same VM is installed and used (1.5.01). Worse.
I recompiled it to be used under 1.4.2 and make eclipse use this VM
(Window/preferences/java/installed jre's), and it remained the same -- works
fine with "java test" and throws exception under the IDE. The same .class
code, without any recompilation.
Please help.
10x in advane.
Sergey
Previous Topic:Eclipse Deployment
Next Topic:Eclipse does not start - ExceptionInInitializerError
Current Time: Fri Nov 07 10:12:50 EST 2025
Powered by FUDForum. Page generated in 0.09961 seconds
