Home » Language IDEs » Java Development Tools (JDT) » Hot Swap
Hot Swap [message #1824] Tue, 22 April 2003 19:04 Go to next message
I can't get Hot Swap features of a Java 1.4.1_02 compiler working inside
the latest Eclipse debugger. I set the debugger JRE to use the 1.4.1_02
as well, debug to a breakpoint, make a change, save, and I always get a
obsolete method warning without a Hot Swap.
Any ideas? Or can you point me in the right direction?
Shane
Re: Hot Swap [message #1840 is a reply to message #1824] Tue, 22 April 2003 23:20 Go to previous messageGo to next message
What type of code change are you attempting?
Are you changing the "shape" of the class...adding or removing a method or
field?
Are you changing code within an inner class?
Darins
"Shane J. Eaker" <eakersj@yahoo.com> wrote in message
news:b84hqd$2aa$1@rogue.oti.com...
> Shane
Re: Hot Swap [message #2342 is a reply to message #1840] Wed, 23 April 2003 09:19 Go to previous messageGo to next message
None of the code changes I've tried have been that sophisticated. Just
something simple to test that the Hot Swap is working while debugging. For
example, changing a String printing to the console within a method, i.e.
System.out.println("change me"). I am using JUnit.
Shane
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:b8503k$9n4$1@rogue.oti.com...
> field?
> Darins
> > Thanks,
> > Shane
Re: Hot Swap [message #2372 is a reply to message #2342] Wed, 23 April 2003 10:20 Go to previous messageGo to next message
Originally posted by: jared-eclipse.mn.rr.com
One way or another, you're getting burned by your test case. The next time
you're doing real debugging and you want to make a change, let your program
running and see how it goes.
- Jared
> For example, changing a String printing to the console within a method,
> i.e.
> Shane
>> or field?
Re: Hot Swap [message #2491 is a reply to message #2342] Wed, 23 April 2003 11:38 Go to previous messageGo to next message
Of course JUnit is a rather complicated starting point...a bit of reflection
with native methods on the stack :-)
Darins
news:b8638m$2ke$1@rogue.oti.com...
For
> Shane
or
> > field?
> > Darins
inside
1.4.1_02
a
> > > Thanks,
> > > Shane
Re: Hot Swap [message #3756 is a reply to message #2342] Wed, 23 April 2003 14:19 Go to previous messageGo to next message
After a little more testing, Hot Swap works in Eclipse and even while using
JUnit. However, it doesn't appear to work while inside an object
constructor or a main method. These limitations are probably documented
somewhere. I was expecting functionality similar to the Smalltalk language
or IBM Visual Age for Java which have finely tuned Hot Swap capabilities.
Shane
For
> Shane
or
> > field?
> > Darins
inside
1.4.1_02
a
> > > Thanks,
> > > Shane
Re: NoClassDefFoundError though plugin is loaded [message #1813883] Sat, 31 August 2019 18:50 Go to previous message
Previous Topic:Change IDE or change project?
Next Topic:Type and Method binding not working properly in some cases
Current Time: Sat Nov 29 13:32:16 EST 2025
Powered by FUDForum. Page generated in 0.05839 seconds
