Home » Eclipse Projects » Eclipse Platform » servlet issue
servlet issue [message #222008] Mon, 05 April 2004 10:44 Go to next message
Originally posted by: sarah.endress.ge.com
I am trying to compile a servlet, and I am getting the following error
messages from ant.
[javac] Compiling 2 source files to C:\WEB-INF\classes
[javac]
C:\J2SE\Java_Components\Eclipse\eclipse\workspace\MetaDataRe pository2\Java\HelloWorldServlet.java:16:
package javax.servlet does not exist
[javac] import javax.servlet.ServletException;
[javac] ^
[javac]
C:\J2SE\Java_Components\Eclipse\eclipse\workspace\MetaDataRe pository2\Java\HelloWorldServlet.java:17:
[javac] import javax.servlet.ServletOutputStream;
[javac] ^
[javac]
C:\J2SE\Java_Components\Eclipse\eclipse\workspace\MetaDataRe pository2\Java\HelloWorldServlet.java:18:
package javax.servlet.http does not exist
[javac] import javax.servlet.http.HttpServlet;
[javac] ^
[javac]
C:\J2SE\Java_Components\Eclipse\eclipse\workspace\MetaDataRe pository2\Java\HelloWorldServlet.java:19:
[javac] import javax.servlet.http.HttpServletRequest;
[javac] ^
[javac]
C:\J2SE\Java_Components\Eclipse\eclipse\workspace\MetaDataRe pository2\Java\HelloWorldServlet.java:20:
[javac] import javax.servlet.http.HttpServletResponse;
[javac] ^
[javac]
C:\J2SE\Java_Components\Eclipse\eclipse\workspace\MetaDataRe pository2\Java\HelloWorldServlet.java:22:
cannot resolve symbol
[javac] symbol : class HttpServlet
[javac] location: class HelloWorldServlet
[javac] public class HelloWorldServlet extends HttpServlet
[javac] ^
[javac]
C:\J2SE\Java_Components\Eclipse\eclipse\workspace\MetaDataRe pository2\Java\HelloWorldServlet.java:25:
[javac] symbol : class HttpServletRequest
[javac] protected void service(HttpServletRequest request,
HttpServletResponse response)
[javac] ^
[javac]
[javac] symbol : class HttpServletResponse
[javac]
[javac]
C:\J2SE\Java_Components\Eclipse\eclipse\workspace\MetaDataRe pository2\Java\HelloWorldServlet.java:26:
[javac] symbol : class ServletException
[javac] throws ServletException, IOException
[javac] ^
[javac]
C:\J2SE\Java_Components\Eclipse\eclipse\workspace\MetaDataRe pository2\Java\HelloWorldServlet.java:28:
[javac] symbol : class ServletOutputStream
[javac] ServletOutputStream out =
response.getOutputStream();
[javac]
The javax.servlet package is in the correct server lib folder, and I also
tried to manually add it to the build path. An excerpt of my build.xml
file is:
<!-- Global properties for this build -->
<property name="target.classesdir" location="/WEB-INF/classes" />
<property name="src.dir" location="" />
<property name="target.jardir" location="/WEB-INF/lib" />
<property name="webapp.dir" location="MetaDataRepository2/WEB-INF" />
<property name="deploy.dir" location="deploy/" />
<path id="compile.classpath" />
<!-- Task 1: Compile the classes -->
<target name="build-classes" description="compiles the classes">
<mkdir dir="${target.classesdir}" />
<javac destdir="${target.classesdir}" deprecation="true" debug="true"
optimize="false">
<classpath refid="compile.classpath" />
<src>
<pathelement location="${src.dir}" />
</src>
</javac>
</target>
I'm not sure why it's not finding the javax.servlet package, but the
standard pieces of servlet code such as import
javax.servlet.http.HttpServletResponse; are not compiling. I've search a
number of newsgroups both within this site and externally, but am unable
to find a suitable answer. Any suggestions? (Note: I also tried setting
the includeAntRuntime variable to "no", but that did not work either).
Thanks!
Re: servlet issue [message #222093 is a reply to message #222008] Mon, 05 April 2004 12:56 Go to previous message
Uh think about it. You've not included the appropriate j2ee libraries
in your classpath.
On Mon, 5 Apr 2004 14:44:24 +0000 (UTC), sarah.endress@ge.com (Sarah
>messages from ant.
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac]
> [javac]
> [javac] ^
> [javac]
> [javac]
>file is:
>optimize="false">
> <src>
> </src>
> </javac>
> </target>
>Thanks!
Previous Topic:How to close the editor if it is open when the file is deleted programmatically?
Next Topic:view and perspective
Current Time: Sun Aug 31 07:18:44 EDT 2025
Powered by FUDForum. Page generated in 0.03289 seconds
