| Hot Swap [message #1824] |
Tue, 22 April 2003 19:04  |
I can't get Hot Swap features of a Java 1.4.1_02 compiler working inside
the latest Eclipse debugger. I set the debugger JRE to use the 1.4.1_02
as well, debug to a breakpoint, make a change, save, and I always get a
obsolete method warning without a Hot Swap.
Any ideas? Or can you point me in the right direction?
Shane
| Re: Hot Swap [message #3756 is a reply to message #2342] |
Wed, 23 April 2003 14:19   |
After a little more testing, Hot Swap works in Eclipse and even while using
JUnit. However, it doesn't appear to work while inside an object
constructor or a main method. These limitations are probably documented
somewhere. I was expecting functionality similar to the Smalltalk language
or IBM Visual Age for Java which have finely tuned Hot Swap capabilities.
Shane
"Shane J. Eaker" <eakersj@yahoo.com> wrote in message
news:b8638m$2ke$1@rogue.oti.com...
> None of the code changes I've tried have been that sophisticated. Just
> something simple to test that the Hot Swap is working while debugging.
For
> example, changing a String printing to the console within a method, i.e.
> System.out.println("change me"). I am using JUnit.
> Shane
> "Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
> news:b8503k$9n4$1@rogue.oti.com...
> > What type of code change are you attempting?
> > Are you changing the "shape" of the class...adding or removing a method
or
> > field?
> > Are you changing code within an inner class?
> > Darins
> > news:b84hqd$2aa$1@rogue.oti.com...
inside
1.4.1_02
a
> > > Thanks,
> > > Shane
FUDForum. Page generated in 0.04348 seconds
