Home » Eclipse Projects » GEF » How to give feedback via a MessageBox within an EditPolicy
How to give feedback via a MessageBox within an EditPolicy [message #221846] Mon, 21 August 2006 09:53 Go to next message
Originally posted by: robert.moestl.joanneum.at
Hello!
Under certain circumstances deleting of editparts should not be possible
in my graphical editor because otherwise my underlying model would
become corrupt. If deleting of an editpart is not allowed I want to show
a MessageBox to inform the user about the reason.
I open the MessageBox within the overridden
ComponentEditPolicy#createDeleteCommand. Unfortunately the MessageBox -
when deleting is not allowed - is always shown just when the editpart
got selected and that's too early. When the key 'DEL' is pressed nothing
happens (the selected editparts won't be deleted) what means that no
MessageBox comes up.
So what I want to do is that when the user tries to delete something
which can't be deleted for some reasons, a MessageBox should inform the
user.
Does somebody know how to manage this?
Thanks in advance
Robert
Re: How to give feedback via a MessageBox within an EditPolicy [message #221887 is a reply to message #221846] Mon, 21 August 2006 10:45 Go to previous messageGo to next message
Hi Robert,
how about open the MessageDialog inside the execute() of the
DeleteCommand???
But why don't you just make the command unexecutable (Command#canExecute())?
Andreas
Robert Möstl schrieb:
> Hello!
> user.
> Thanks in advance
> Robert
Re: How to give feedback via a MessageBox within an EditPolicy [message #221900 is a reply to message #221846] Mon, 21 August 2006 10:49 Go to previous messageGo to next message
Even the workbench's undo framework doesn't seem to handle this. You
probably want canExecute() to return an IStatus, instead of a boolean. There
would also be the issue of combining the status from multiple contributions
to the command.
So, would you have the "Delete" menuitem enabled, and then popup a message
when the user invokes the menuitem? That seems a bit odd, unless it is a
rare case.
"Robert M
Re: How to give feedback via a MessageBox within an EditPolicy [message #221914 is a reply to message #221900] Mon, 21 August 2006 11:18 Go to previous message
Thanks for the answers!
Yes I want to have the "Delete" menuitem enabled and then popup a
message when the user invokes it. I know that's a little bit strange,
but I can't forbid the user to press "DEL" on the keyboard. So if the
user does so and nothing happens he would not know what is going on.
Therefore I want to give the user feedback that he have to delete
something else before he is able to delete that.
Hope the requirement is clear?!
Best regards Robert
> to the command.
> rare case.
> "Robert Möstl" <robert.moestl@joanneum.at> wrote in message
> news:eccdqp$8pd$1@utils.eclipse.org...
>> Hello!
>> in my graphical editor because otherwise my underlying model would become
>> corrupt. If deleting of an editpart is not allowed I want to show a
>> when deleting is not allowed - is always shown just when the editpart got
>> So what I want to do is that when the user tries to delete something which
>> can't be deleted for some reasons, a MessageBox should inform the user.
>> Thanks in advance
>> Robert
Previous Topic:figure of TextCompartmentEditPart is not visible
Next Topic:How to manage a CellEditor
Current Time: Thu Jul 17 23:44:08 EDT 2025
Powered by FUDForum. Page generated in 0.03663 seconds
