Home » Archived » Voicetools » VTP Browser API
VTP Browser API [message #21489] Sat, 07 February 2009 15:06 Go to next message
I'm trying to test this example of " Using the VTP Browser API" but have
errors on:
import org.eclipse.vtp.launching.IVoiceXMLBrowser;
import org.eclipse.vtp.launching.IVoiceXMLBrowserConstants;
import org.eclipse.vtp.launching.VoiceXMLBrowserInput;
import org.eclipse.vtp.launching.VoiceXMLBrowserProcess;
import org.eclipse.vtp.launching.VoiceXMLLogMessage;
Where do I find this Plugin dependencies?
Re: VTP Browser API [message #21505 is a reply to message #21489] Sun, 08 February 2009 18:28 Go to previous messageGo to next message
> errors on:
> Thanks
What problems are you having? You want to get the source for the plugin
from the Voice Tools Project SVN repository. Open Eclipse with the SVN
support installed, and use the Import Projects from SVN command to
locate and fetch the source of the org.eclipse.vtp.launching plugin.
Under the SVN repository, use the path: Debug > trunk > plugins.
There seems to currently be a problem with the SVN repository link to
the ROOT structure. I don't think the org.eclipse.vtp.launching plugin
has changed in a long time, however.
Once you have that project loaded up in eclipse, you can use the
plugin.xml file to review all the dependencies, etc.
Hope that helps.
-- Mike
Re: VTP Browser API [message #21622 is a reply to message #21505] Wed, 25 February 2009 14:08 Go to previous message
you helped me very
thanks
Re: VTP Browser API [message #578037 is a reply to message #21489] Sun, 08 February 2009 18:28 Go to previous message
> errors on:
> Thanks
Hope that helps.
-- Mike
Re: VTP Browser API [message #578102 is a reply to message #21505] Wed, 25 February 2009 14:08 Go to previous message
you helped me very
thanks
Previous Topic:Web Services Problem
Next Topic:How to debug openVXML?
Current Time: Sat Aug 02 03:13:52 EDT 2025
Powered by FUDForum. Page generated in 0.06362 seconds
