Home » Modeling » TMF (Xtext) » Re: [TCS] TCS helpers
Re: [TCS] TCS helpers [message #21473] Thu, 11 September 2008 14:10 Go to next message
Alfons,
I believe that the correct location of posting TCS issues
is eclipse.modeling.tmf; it's unclear why the eclipse,tcs
list has just been created.
Helpers are normally associated with ATL transformations. I
suspect that the projects that you've seen are using ATL
to transform models output from a TCS parse (injection), that
are conformant with one meta-model, into models conformant with a
different meta-model. This will definitely be true if the projects
that you've seen are ATL/AM3 dsls.
Andy.
"Alfons Laarman" <a.w.laarman@student.utwente.nl> wrote in message
news:gab9sh$q2n$1@build.eclipse.org...
> Hello,
> Can somebody tell me something about TCS helpers?
> I noticed some TCS projects having a Helpers directory containing some
> queries. I guess for helping the parse operation?
> What about the constraints in the WZR dir?
> Kind regards,
> Alfons
Re: [TCS] TCS helpers [message #21782 is a reply to message #21473] Tue, 14 October 2008 10:40 Go to previous message
Andy, thanks for your answer :-).
Alfons, here are some more details to complete Andy's answer:
Basically, a language project includes a metamodel (.km3), a concrete
syntax (.tcs), and possibly some transformations (e.g., to implement the
language in terms of another, like KM32Ecore.atl).
Helpers which may be reused by several such transformations are
generally identified as such in a Helpers folder.
The WFR folder (when existing) contains Well-Formedness Rules, which are
implemented as a transformation from the language metamodel to a Problem
(diagnostic) metamodel. This transformation may be implemented in ATL or
in a specific DSL for such constraints [1]. It can be automatically
executed by TGE, as long as it runs on the ATL VM.
[1] Bézivin, J, and Jouault, F : Using ATL for Checking Models. In:
Proceedings of the International Workshop on Graph and Model
Transformation (GraMoT), Tallinn, Estonia. 2005.
Frédéric
Andy Carpenter a écrit :
> Alfons,
> Andy.
>> Hello,
>> Kind regards,
>> Alfons
Previous Topic:[Announce] TMF Xtext 0.7.0 I200809181137 is available
Next Topic:[TCS] package notation for recursive namespace
Current Time: Mon Aug 04 01:41:03 EDT 2025
Powered by FUDForum. Page generated in 0.04867 seconds
