Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EDataType and '<' operation in OCL expression
EDataType and '<' operation in OCL expression [message #21447] Tue, 07 February 2006 12:07 Go to next message
Is '<' operation defined for EDataType which points by
EDataType::instanceClass to a java class which
implements Comparable?
As mentioned in the thread 'order of returned items', the 'sortedBy'
operation on collections implemented by EMFT
understands the definition of '<' operation as implementation of
'java.lang.Comparable' interface.
It works for me in the following example with use of ecore::EDate:
This is the context classifier described in emfatic source.
class Topic {
attr String[1] name;
attr Date startDate;
attr Date endDate;
1) the following expression works fine and is evaluated by using
'java.util.Date.compareTo'.
Bag { startDate, endDate }->sortedBy(d|d)->last() = endDate
2) but the expression below fails with: "AnyType: the source of operation:
(lessThan) must be an EClass"
startDate < endDate
Am I wrong to expect that if '<' was found as defined in 'sortedBy' it
should be resolved also in the second expression?
/Radek
Re: EDataType and '<' operation in OCL expression [message #21463 is a reply to message #21447] Tue, 07 February 2006 18:44 Go to previous messageGo to next message
Hi, Radek,
You should absolutely expect that '<', '>', '<=', and '>=' would be
supported for EDataTypes implementing the Comparable interface. As I read
the OCL spec, any OCL type (including types defined by a model) should be
able to define these infix operations (also arithmetic and boolean
operations, but that's another matter).
Sounds like a bug!
Christian
Radek Dvorak wrote:
> class Topic {
> attr Date endDate;
> startDate < endDate
> /Radek
Re: EDataType and '<' operation in OCL expression [message #21472 is a reply to message #21463] Wed, 08 February 2006 03:47 Go to previous message
I have raised https://bugs.eclipse.org/bugs/show_bug.cgi?id=126872
/Radek
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:dsbbcq$u77$1@utils.eclipse.org...
> Hi, Radek,
> Sounds like a bug!
> Cheers,
> Christian
> Radek Dvorak wrote:
>> class Topic {
>> attr Date endDate;
>> operation:
>> startDate < endDate
>> Regards,
>> /Radek
Re: EDataType and '<' operation in OCL expression [message #566198 is a reply to message #21447] Tue, 07 February 2006 18:44 Go to previous message
Hi, Radek,
Sounds like a bug!
Christian
Radek Dvorak wrote:
> class Topic {
> attr Date endDate;
> startDate < endDate
> /Radek
Re: EDataType and '<' operation in OCL expression [message #566253 is a reply to message #21463] Wed, 08 February 2006 03:47 Go to previous message
/Radek
> Hi, Radek,
> Sounds like a bug!
> Cheers,
> Christian
> Radek Dvorak wrote:
>> class Topic {
>> attr Date endDate;
>> operation:
>> startDate < endDate
>> Regards,
>> /Radek
Previous Topic:EDataType and '<' operation in OCL expression
Next Topic:CDO performance problems
Current Time: Mon Nov 10 02:34:07 EST 2025
Powered by FUDForum. Page generated in 0.05574 seconds
