Home » Newcomers » Newcomers » Bug: Eclipse on linux are not reading my eclipse.ini
Bug: Eclipse on linux are not reading my eclipse.ini [message #219974] Thu, 05 July 2007 08:21 Go to next message
Originally posted by: tiller.daimi.au.dk
I have just downloaded the new eclipse 3.3 for Linux (The one called
Eclipse IDE for Java Developers)
And it is working, but it's not reading the included eclipse.ini file.
This causes the problems that the std heap size is something like 12MB
and the max heap size is 64MB.
Does anyone know what can cause eclipse to ignore eclipse.ini?
Martin T
Re: Bug: Eclipse on linux are not reading my eclipse.ini [message #219982 is a reply to message #219974] Thu, 05 July 2007 08:34 Go to previous messageGo to next message
Every single argument must be on a new line. Confirm this. I think
leading/trailing whitespaces may be a problem, also confirm this.
Rem
Re: Bug: Eclipse on linux are not reading my eclipse.ini [message #220097 is a reply to message #219982] Thu, 05 July 2007 09:57 Go to previous message
I found the problem. I had renamed my eclipse to eclipse.real and
then eclipse need the ini file to be called eclipse.real.ini insted of
eclipse.ini
I don't know if this is a feature or a bug, but renaming the eclipse
file did not cause this problem when I was running the eclipse3.3 RC3/4
Well it's working now.
> Rem
Previous Topic:installation of web tools project on windows xp
Next Topic:Eclipse is not working properly
Current Time: Tue Jul 22 15:42:35 EDT 2025
Powered by FUDForum. Page generated in 0.07810 seconds
