| Unhandled event loop exception [message #21348] |
Mon, 09 June 2008 15:44  |
Originally posted by: tcelvis.gmail.com
I am trying to follow the guidelines in the IMP users guide (May 2008).
I have sucessfully created an IMP project, but I get an error "Unhandled
event loop exception" when I attempt to use the Language description
wizard.
Error details:
eclipse.buildId=M20071023-1652
java.version=1.6.0_10-beta
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=da_DK
Command-line arguments: -os win32 -ws win32 -arch x86
This is a continuation of log file K:\Eclipse RCP
Workspace\.metadata\.bak_0.log
Created Time: 2008-04-26 00:33:58.718
Error
Mon Jun 09 21:42:26 CEST 2008
java.lang.NoSuchMethodError:
org.eclipse.pde.internal.core.PluginModelManager.getAllPlugi ns()[Lorg/eclipse/pde/core/plugin/IPluginModelBase;
org.eclipse.imp.wizards.IMPWizardPage.getPluginModel(IMPWiza rdPage.java:694)
org.eclipse.imp.wizards.CodeServiceWizard.getStandardSubstit utions(CodeServiceWizard.java:311)
org.eclipse.imp.wizards.CodeServiceWizard.getStandardSubstit utions(CodeServiceWizard.java:287)
at org.eclipse.imp.wizards.NewLanguage.performFinish(NewLanguag e.java:189)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:742)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:616)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:182)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Any hints on what I need to do to resolve this ?
Thomas Christensen
| Re: Unhandled event loop exception [message #21475 is a reply to message #21459] |
Sat, 14 June 2008 09:18  |
Hello Thomas,
I believe that the problem that you saw on Eclipse 3.3 was due to the
use of the 3.2.72 feature. I believe that the exception that you saw
originally is due to changes in plug-in model management between 3.2 and
3.3; we had not yet addressed those in the 3.2.* releases.
I am running on both Eclipse 3.3 and 3.4 with IMP releases 0.1.73 and
0.1.74 without seeing this exception. If you can try that I think you
should get much farther than before.
Of course, I cannot guarantee that you won't run into a later exception
:-), but at least it shouldn't be of the same type.
Stan
Thomas Christensen wrote:
> My IMP-related plugins in my Eclipse RCP are a mix of versions 1.0.72,
> 1.0.73 and 3.2.72.
> The IMP-plugins in my Eclipse 3.2 are versions 0.1.73 and 0.1.74
| Re: Unhandled event loop exception [message #571167 is a reply to message #21348] |
Wed, 11 June 2008 13:51  |
> wizard.
> Error details:
> Error
Is this 3.2, 3.3, or 3.4? (I can't quite tell from the build ID.)
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IMP Team Lead (http://www.eclipse.org/imp)
X10: Productivity for High-Performance Parallel Programming (http://x10.sf.net)
| Re: Unhandled event loop exception [message #571255 is a reply to message #21429] |
Wed, 11 June 2008 16:41  |
Hi Robert,
It was on:
Eclipse RCP
Version: 3.3.1.1
Build id: M20071023-1652
I have swtched to:
Eclipse
Version: 3.2.1
Build id: M20060921-0945
Using 3.2, I have managed to get as far as using the
New LPG Grammar with Parser Wrapper for IMP wizard
sucessfully, and created a lexer and parser with the
sample grammar.
So I guess it seems to be working :-)
Thomas
| Re: Unhandled event loop exception [message #571277 is a reply to message #21444] |
Wed, 11 June 2008 19:00  |
Hi Thomas,
Really you shouldn't have to move backward in your Eclipse version to
get things working (although I applaud your determination). I've been
able to run through our whole demo (multiple wizards) on Eclipse 3.3.1.1
without problems. I have an SDK installation but it has the same build
id as your RCP version.
My recollection is a bit hazy, but I believe that the method at the top
of the stack trace that you provided is one of the ones where there were
differences between 3.2 and 3.3/3.4. But those differences were
something that I thought we had reconciled.
So I guess the next question is, what version of IMP plug-ins do you
have? I'm running with 0.1.74.
Stan
> Hi Robert,
> It was on: Eclipse RCP Version: 3.3.1.1
> I have swtched to:
> Eclipse
> Version: 3.2.1
> �New LPG Grammar with Parser Wrapper for IMP� wizard
> sample grammar.
> Regards
> Thomas
| Re: Unhandled event loop exception [message #571428 is a reply to message #21459] |
Hello Thomas,
Stan
> 1.0.73 and 3.2.72.
FUDForum. Page generated in 0.05215 seconds
