Home » Eclipse Projects » Subversive » pure Java connector
pure Java connector [message #21341] Fri, 13 June 2008 04:50 Go to next message
Hi there,
I installed subversive on a Linux Machine with the JavaHL connector.
Without the native JavaHL libraries, I get obviously an exception and
additionally the hint that I can install a *"pure Java connector"* from
the connector home page.
What is that pure Java connector and where can I get it? That would be
much more comfortable for beginners to install as there is no dependency
to some native library where you have to set the java.library.path
accordingly.
Hauke
Re: pure Java connector [message #21349 is a reply to message #21341] Fri, 13 June 2008 05:16 Go to previous messageGo to next message
Hi Hauke,
If you want to use pure java, you'll need the SVNKit connector. It's not
available from Eclipse.org due to licensing restrictions but you can
find it on this update site:
http://www.polarion.org/projects/subversive/download/eclipse /2.0/update-site/
Thomas Hallgren
Hauke Fuhrmann wrote:
> Hi there,
> accordingly.
> Cheers,
> Hauke
Re: pure Java connector [message #21356 is a reply to message #21349] Fri, 13 June 2008 06:38 Go to previous messageGo to next message
Thomas Hallgren wrote:
> Hi Hauke,
Thanks! I tried that, but get a strange dependency problem for both the
SVNKit 1.1.7 and 1.2.0:
"Cannot complete the request. See the details.
Cannot find a solution satisfying the following requirements
Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.datatools.connectivity .ui/[1.1.0.v200805310538,1.1.0.v200805310538]]. "
Is this a Subversive specific problem or some issue with the P2 update
utility?
Hauke
Re: pure Java connector [message #21379 is a reply to message #21356] Sat, 14 June 2008 05:17 Go to previous message
Originally posted by: alexander.gurov.polarion.org
Hello Hauke,
It looks very similar to problems described in:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=229104
and
https://bugs.eclipse.org/bugs/show_bug.cgi?id=230233
Previous Topic:Integration for the Mylyn Project not compatable with Mylyn 2.3.2
Next Topic:subversive asks 100 times a day for password
Current Time: Tue Nov 04 22:31:57 EST 2025
Powered by FUDForum. Page generated in 0.04017 seconds
