Home » Eclipse Projects » Plugin Development Environment (PDE) » eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects)
eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #21305] Fri, 12 September 2008 11:40 Go to next message
Originally posted by: ekkehard.gentz-software.de
after refactoring-renaming some plug-in projects I noticed a significant
slow-down at
* start-up
* saving MANIFEST.MF
* saving built.properties
* opening / closing plug-in projects
saving .java
opening / closing non-plug-in projects
is as fast as before
starting with -clean doesnt help
ekke
Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #21548 is a reply to message #21305] Fri, 12 September 2008 11:46 Go to previous messageGo to next message
Originally posted by: zx.code9.com
> slow-down at
> * start-up
> saving .java
How big is your target platform in terms of plug-ins?
~ Chris
Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #21587 is a reply to message #21548] Fri, 12 September 2008 12:12 Go to previous messageGo to next message
Chris Aniszczyk schrieb:
>> significant slow-down at
>> * start-up
>> saving .java
around 600 (RCP, Equinox, Riena, Easybeans, some from SpringSource)
I went back and restored eclipse app folder and complete workspace from
TimeMachine
....all is fast as before
then again changed 5 plug-in names (because its no good idea to have
projects in workspace ending with .service on OSX ;-)
....and its slow
really curious...
ekke
> Cheers,
> ~ Chris
Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #21631 is a reply to message #21587] Fri, 12 September 2008 12:25 Go to previous messageGo to next message
>>> * start-up
>>> saving .java
> TimeMachine
> ...and its slow
> really curious...
additional info:
opening build.properties
removing /src
saving
needs 210 seconds ... only watching the colored wheel cursor
and CPU activity is 100%
ekke
> ekke
>> Cheers,
>> ~ Chris
Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #21676 is a reply to message #21631] Fri, 12 September 2008 12:41 Go to previous messageGo to next message
>>>> * start-up
>>>> saving .java
>> from TimeMachine
>> ...and its slow
>> really curious...
> additional info:
> removing /src
> saving
additional info:
Target Platform - Load Target, Apply
....Resetting Target Platform needs 180 seconds
ekke
> ekke
>> ekke
>>> Cheers,
>>> ~ Chris
Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #22571 is a reply to message #21676] Wed, 17 September 2008 04:30 Go to previous message
ekke schrieb:
>>>>> * start-up
>>>>> saving .java
>>> from TimeMachine
>>> ...and its slow
>>> really curious...
>> additional info:
>> removing /src
>> saving
> additional info:
> ekke
>> ekke
>>> ekke
>>>> Cheers,
>>>> ~ Chris
Chris,
finally I found out that the renaming of the projects wasn't the reason.
the slowdown was caused by Cycles and wrong package-uses
(see bugzilla 208011, bugzilla 246615) PDE detects in 3rdparty bundles.
all things caused by some bundles from easybeans where PDE detects
cycles and if my own bundles have dependencies via package-import then
sometime trouble starts.
I found some workarounds to minimize trouble loading some fake bundles
into workspace ;-)
in the meantime I know, if "resetting target platform" or "starting
eclipse - initialize java tooling - configuring plugin-dependencies"
takes a long time then I have to look thru my bundles in workpace to see
if there's a plug-in dependency to easybeans.core then I have to
workaround this.
so today I got my startup .... configuring plugin-dependencies from more
then 5 minutes to 1 second
I also from time to time get not only cycles - also wrong package-uses,
but I'm still working to make a small example reproduceable for bugzilla
246615.
ekke
Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #580110 is a reply to message #21305] Fri, 12 September 2008 11:46 Go to previous message
> slow-down at
> * start-up
> saving .java
~ Chris
Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #580142 is a reply to message #21548] Fri, 12 September 2008 12:12 Go to previous message
>> * start-up
>> saving .java
TimeMachine
....and its slow
really curious...
ekke
> Cheers,
> ~ Chris
Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #580168 is a reply to message #21587] Fri, 12 September 2008 12:25 Go to previous message
>>> * start-up
>>> saving .java
> TimeMachine
> ...and its slow
> really curious...
additional info:
removing /src
saving
ekke
> ekke
>> Cheers,
>> ~ Chris
Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #580192 is a reply to message #21631] Fri, 12 September 2008 12:41 Go to previous message
>>>> * start-up
>>>> saving .java
>> from TimeMachine
>> ...and its slow
>> really curious...
> additional info:
> removing /src
> saving
additional info:
ekke
> ekke
>> ekke
>>> Cheers,
>>> ~ Chris
Re: eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects) [message #580662 is a reply to message #21676] Wed, 17 September 2008 04:30 Go to previous message
ekke schrieb:
>>>>> * start-up
>>>>> saving .java
>>> from TimeMachine
>>> ...and its slow
>>> really curious...
>> additional info:
>> removing /src
>> saving
> additional info:
> ekke
>> ekke
>>> ekke
>>>> Cheers,
>>>> ~ Chris
Chris,
into workspace ;-)
workaround this.
246615.
ekke
Previous Topic:p2'izing an application takes too long
Next Topic:Problem Installing plug-ins on Ganymede through P2 Update Manager on Windows Vista
Current Time: Mon Nov 03 23:31:18 EST 2025
Powered by FUDForum. Page generated in 0.57778 seconds
