Home » Archived » EPF » amd64 version of epf-composer?
amd64 version of epf-composer? [message #21294] Sat, 21 October 2006 12:32 Go to next message
Originally posted by: victorkane.gmail.com
Hi there.
I have downloaded the epf standard 1.0 version, and on my Ubuntu laptop
it runs right off the shelf (with sun-sdk 1.5 java installed).
Now, on my desktop, which is running amd64 ubuntu, I have been able to
download and successfully run the regular eclipse compiled for amd64.
However, of course the regular linux epf-composer won't run (says it has
trouble finding gtk icons).
Is there a amd64 build for epf-composer? Or are there instructions
somewhere on how to build myself?
Thank you so much,
Victor Kane
Re: amd64 version of epf-composer? [message #21535 is a reply to message #21294] Mon, 23 October 2006 14:21 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
Victor
You can always get source code from CVS respository and build EPF yourself
OR run from your existing Eclipse Shell directly. Here are instructions
how to set it up http://www.eclipse.org/epf/composer_dev_guide/
Re: amd64 version of epf-composer? [message #567005 is a reply to message #21294] Mon, 23 October 2006 14:21 Go to previous messageGo to next message
Victor
Re: amd64 version of epf-composer? [message #1091956 is a reply to message #21294] Thu, 22 August 2013 02:28 Go to previous message
Hi! The following steps worked for me:
1. Install the 32-bit version of xulrunner:
ftp://ftp.mozilla.org/pub/mozilla.org/xulrunner/releases/1.9.2.9/runtimes/xulrunner-1.9.2.9.en-US.linux-i686.tar.bz2
2. Run: gedit ~/.profile
3. Write:
export MOZILLA_FIVE_HOME=".../xulrunner"
export LD_LIBRARY_PATH="$MOZILLA_FIVE_HOME:$LD_LIBRARY_PATH"
(... stands for the path where you have decompressed xulrunner).
4. Install the 32-bit version of EPF composer.
5. Run: ./epf -vm /usr/lib/jvm/jre1.7.0_03_32bit/bin
EPF Composer runs on a 32-bit JVM.
Cheers!
Previous Topic:Basic instructions to setup egit to get source
Next Topic:Problem with character + in a link
Current Time: Tue Nov 04 09:37:07 EST 2025
Powered by FUDForum. Page generated in 0.26236 seconds
