Home » Modeling » GMF (Graphical Modeling Framework) » Can 2.2.0M5a be installed with eclipse 3.5M5?
Can 2.2.0M5a be installed with eclipse 3.5M5? [message #219044] Mon, 16 February 2009 21:24 Go to next message
Originally posted by: eclipse-newsgroups.scharf.gr
is 2.2.0M5a supposed to work with eclipse 3.5M5?
My update manager complains about:
Cannot find a solution satisfying the following requirements org.eclipse.ltk.core.refactoring [3.4.0.v20080603-2000].
It seems to me it requires eclipse 3.4???
Michael
Michael Scharf
Wind River Systems GmbH
http://www.WindRiver.com
http://MichaelScharf.blogspot.com/
Re: Can 2.2.0M5a be installed with eclipse 3.5M5? [message #219066 is a reply to message #219044] Tue, 17 February 2009 06:16 Go to previous messageGo to next message
The Galileo build uses p2 to install each project and then construct a
product, so it's effectively installed twice (once from our update site, and
again from the repo generated by the build process). I'm quite certain it
works with the platform's M5.
Are you sure you have all of the required dependencies installed correctly?
I'd say grab it from the Hudson staging site used to build Galileo, but
there are still some server issues at Eclipse, it seems.
- Rich
On 2/16/09 9:24 PM, in article gnd75m$c0c$1@build.eclipse.org, "Michael
Scharf" <eclipse-newsgroups@scharf.gr> wrote:
> Hi
> Michael
Re: Can 2.2.0M5a be installed with eclipse 3.5M5? [message #219107 is a reply to message #219066] Tue, 17 February 2009 10:02 Go to previous messageGo to next message
Really strange! I use a freshly installed eclipse SDK 3.5M5 and
I tried to install 2.2.0.M5a from:
http://download.eclipse.org/modeling/gmf/updates/milestones/
(do I need any other update site)
the ltk plugin is there and can be started!
but p2 complains that it cannot find a solution satisfying
Hmm, maybe this is a p2 problem....
Michael
> - Rich
>> Hi
>> Michael
Michael Scharf
Solution for: Can 2.2.0M5a be installed with eclipse 3.5M5? [message #219114 is a reply to message #219107] Tue, 17 February 2009 11:15 Go to previous message
Here is the p2 bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=264525
The message has nothing to do with the real problem.
One solution is to add the GMF, the EMF *and* the staging update site:
http://build.eclipse.org/galileo/staging/
http://download.eclipse.org/modeling/emf/updates/milestones/
Michael
> Michael
>> site, and
>> certain it
>> correctly?
>> - Rich
>>> Hi
>>> Michael
Michael Scharf
Previous Topic:Auto-generating tool commands.
Next Topic:[Templates] Couldn't find operation 'eContainer()'
Current Time: Tue Jul 22 02:32:07 EDT 2025
Powered by FUDForum. Page generated in 0.07112 seconds
