containers editparts - example-tutorial needed [message #218543] |
Mon, 26 June 2006 11:39  |
Hi! Well, I'll try to explain my problem in my poor english, so please be patient ;-)
I'm trying to implement a simple container for my gef editor. I have read the GEF-FAQ
and done what it says. Also I have looked the logic example source code, but when
moving a widget from a container to another an error occurs. Supose the edit part of
the container is called ContainerEditPart. Here is what i'm doing:
1) install CONTAINER and LAYOUT policies in ContainerEditPart.
2) implement getModelChildren() in ContainerEditPart
3) in the CONTAINER edit policy (extends ContainerEditPolicy), getOrphanChildrenCommand()
is responsably for returning a command that remove the element of the old parent
4) in the LAYOUT editPolicy (extends XYLayoutEditPolicy), getAddCommand() is responsably
for returning a command that adds the element to the new parent
5) these both returned commands modify the model correctly and fire propertyChange events
to corresponding editparts.
6) In editpart's propertyChange() method I do refreshChildren(). it's sufficient with
this or I have to do something else here?
The error manifestation: I think refreshChildren() creates new editparts but isn't
erasing the edit parts corresponding to the elements in the old parent. Still more:
When I try to visually manipulate the added element with the mouse, but it seems that
it is accessing to the old edit part and not the new one.
Well, I don't hope you understand me... but I do hope you correct the steps bellow
for implementing the container. Also It would be very nice if you point me to a very
simple example that implements containers (not logic-example, please) or a tutorial.
Thanks very much!
Sebastian Gurin
Re: containers editparts - example-tutorial needed [message #218708 is a reply to message #218543] |
Wed, 28 June 2006 04:46  |
Please ignore this message. I had an stupid error (bad reimplementation of EditPart.deactivate()).
Like always, gef was doing the right thing. My apologies.
On Mon, 26 Jun 2006 17:39:14 +0200
> Thanks very much!
> Sebastian Gurin
FUDForum. Page generated in 0.03307 seconds
