Home » Language IDEs » Java Development Tools (JDT) » debugger cannot locate source file
debugger cannot locate source file [message #218141] Mon, 31 October 2005 23:21 Go to next message
Originally posted by: ddruding.cfl.rr.com
I am trying to stop at a breakpoint in a VERY simple java program (i.e.,
HelloWorld).
When the IDE switches to the Debug perspective, a tab appears with the title
"HelloWorld.main(String[]) line:21".
The first line of text in the tab is "Source not found.", followed by a
button with the following text:
"Edit Source Lookup Path...". The directory containing HelloWorld.java is
in the list of folders displayed in the dialog activated by clicking that
button.
The project properties page indicates that there are not any project
specific settings.
Workspace Settings for the compiler have all the classfile generation
options selected.
The error log contains the following:
Message: Error logged from Debug Core:
Exception Stack Trace:
java.lang.NoClassDefFoundError:
org/eclipse/jdt/internal/debug/core/JavaDebugUtils
org.eclipse.jdt.launching.sourcelookup.containers.JavaSource LookupParticipan
t.getSourceName(JavaSourceLookupParticipant.java:60)
org.eclipse.debug.core.sourcelookup.AbstractSourceLookupPart icipant.findSour
ceElements(AbstractSourceLookupParticipant.java:60)
org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor$SourceLooku
pQuery.run(AbstractSourceLookupDirector.java:126)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor.doSourceLoo
kup(AbstractSourceLookupDirector.java:461)
org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor.getSourceEl
ement(AbstractSourceLookupDirector.java:711)
ement(AbstractSourceLookupDirector.java:449)
org.eclipse.jdt.internal.debug.core.hcr.JavaHotCodeReplaceMa nager.getCompila
tionUnit(JavaHotCodeReplaceManager.java:903)
org.eclipse.jdt.internal.debug.core.hcr.JavaHotCodeReplaceMa nager.getAffecte
dFrame(JavaHotCodeReplaceManager.java:801)
dFrames(JavaHotCodeReplaceManager.java:761)
org.eclipse.jdt.internal.debug.core.hcr.JavaHotCodeReplaceMa nager.attemptPop
Frames(JavaHotCodeReplaceManager.java:711)
org.eclipse.jdt.internal.debug.core.hcr.JavaHotCodeReplaceMa nager.doHotCodeR
eplace(JavaHotCodeReplaceManager.java:446)
org.eclipse.jdt.internal.debug.core.hcr.JavaHotCodeReplaceMa nager.access$0(J
avaHotCodeReplaceManager.java:416)
atorg.eclipse.jdt.internal.debug.core.hcr.JavaHotCodeReplace Manager$1.run(Ja
vaHotCodeReplaceManager.java:305)
at org.eclipse.debug.core.DebugPlugin$AsynchJob.run(DebugPlugin .java:1027)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
Anyone out there seen this behavior before?
Dino
Re: debugger cannot locate source file [message #218353 is a reply to message #218141] Fri, 04 November 2005 15:08 Go to previous messageGo to next message
Looks like your Eclipse install has some incompatbile plug-ins. The "class
not found" has been added to the 3.2 development stream of Eclipse. Try a
clean install.
Darin
"Dino Druding" <ddruding@cfl.rr.com> wrote in message
news:dk6qfn$bd5$1@news.eclipse.org...
> HelloWorld).
> title
> button.
> specific settings.
> options selected.
> at
> at
> at
> at
> :1044)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Dino
Re: debugger cannot locate source file [message #218375 is a reply to message #218353] Sat, 05 November 2005 14:10 Go to previous message
Thanks. I was trying to use 3.2M. I dropped back to 3.1.1 and things seem
to be working for me.
"Darin Wright" <Darin_Wright@ca.ibm.com> wrote in message
news:dkgf4o$ltu$1@news.eclipse.org...
> clean install.
> Darin
> > HelloWorld).
> > title
is
that
> > button.
> > specific settings.
> > options selected.
> > at
> > at
> > at
> > at
> > :1044)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > Thanks,
> > Dino
Previous Topic:Trouble adding a JavaLineBreakpoint programmatically
Next Topic:Strange phenomenon with error ticks in package explorer
Current Time: Fri Sep 19 06:25:32 EDT 2025
Powered by FUDForum. Page generated in 0.04840 seconds
