| AspectJ Projects referencing other AspectJ Library Projects [message #21143] |
Tue, 13 May 2003 15:48 |
Originally posted by: eclipse.wingspread.fastmail.fm
In Eclipse, I can define that one project references information contained
in another project. If the source in the related project gets changed,
both projects are rebuilt. If I have an AspectJ project which refers to
another AspectJ project, if I change the definition of an aspect in the
second project, will the compiler weave that new aspect definition into any
project which references the project defining the aspect? For example, if
I have:
Aspect Project - an AspectJ project which defines one or more aspects
App Project - an AspectJ project with no aspects but has 'Aspect Project'
on the build path.
Will a change in the aspect defined in 'Aspect Project' have any effect on
code in the 'App Project', or do I need to generate a jar file from the
Aspect Project and use it as input to the AspectJ compiler used by 'App
Project?'
Thanks.
James Howe
FUDForum. Page generated in 0.05101 seconds
