Home » Newcomers » Newcomers » Putting the existing source code into Project
Putting the existing source code into Project [message #217961] Mon, 25 June 2007 23:51 Go to next message
Originally posted by: haysensei.yahoo.co.nz
I have a source directory structure which i want to put it under eclipse.
I started using eclipse only last week. Any idea what we need to do.
Sally
Re: Putting the existing source code into Project [message #217970 is a reply to message #217961] Tue, 26 June 2007 01:09 Go to previous messageGo to next message
Sally wrote:
> eclipse. I started using eclipse only last week. Any idea what we need
> to do.
> Sally
Hi. In the File / New / New Java Project, on the first screen there is
an option to Create Project From Existing Source. Hope this helps. Mark
Dexter
Re: Putting the existing source code into Project [message #218073 is a reply to message #217970] Tue, 26 June 2007 11:32 Go to previous messageGo to next message
Originally posted by: eclipse5.rizzoweb.com
Mark Dexter wrote:
> Sally wrote:
>> to do.
>> Thanks,
>> Sally
Another option is to use File > Import to bring the existing source
files into a project you have already created.
Hope this helps,
Eric
Re: Putting the existing source code into Project [message #218192 is a reply to message #217961] Tue, 26 June 2007 20:12 Go to previous message
Thanks for the help. I have created the project with the source files in
it.
Sally
Previous Topic:JDT: how to get the workspace from *.internal.compiler.Compiler.process()
Next Topic:problem getting j2me source classes to show when debugging
Current Time: Sun Aug 31 07:11:44 EDT 2025
Powered by FUDForum. Page generated in 0.07268 seconds
