| pluginManagement, extensions versioning issue [message #21123] |
Mon, 19 January 2009 11:21  |
Jetty uses the o.a.felix:maven-bundle-plugin for getting the osgi
manifests in order but lately with the m2e plugin I am getting the
following error for about 20 or so sub-projects (each module declaring
the plugin).
Project build error:Cannot resolve pre-scanned plugin artifact (for use
as an extension): org.apache.felix:maven-bundle-plugin: Failed to
resolve extension plugin:
org.apache.felix:maven-bundle-plugin:maven-plugin:RELEASE pom.xml jetty
line 1 Maven Problem
The top level project file declares the version (1.4.0) in the
pluginManagement section but that doesn't seem to matter. There are
some relativePath statements that might be a factor, and then the plugin
declaration also includes <extension>true</extension>
thoughts?
jesse
| Re: pluginManagement, extensions versioning issue [message #21699 is a reply to message #21186] |
Sat, 07 February 2009 23:23  |
Originally posted by: lists.remove-me.varnes.remove-me.net
* Jesse McConnell wrote, On 24/01/09 07:10:
>> david varnes wrote:
>> I can confirm this as well. If the version of the bundle plugin is
>> inherited from a parent <pluginManagement>, this problem occurs.
>> Specifying the version locally is a (unpalatable) work-around.
>> I have been thinking it is because the bundle plugin is declared
>> as an extension ?
> Agreed, that was my suspicion..
>> thanks
>> davidv
A search of JIRA brings up quite a few issues with extension related
origins. I am sure the response will be to see if the issues go away
with the merge of an updated 3.x embedder.
In the meantime, responding to Jason's call for voting on issues,
the following issue seems to match our case, you may consider
voting:
http://jira.codehaus.org/browse/MNGECLIPSE-487
regards
davidv
FUDForum. Page generated in 0.04916 seconds
