Filtering Outline View [message #217671] |
Mon, 23 June 2008 11:59  |
Is there a way to filter the Outline view so only the functions appear? I
would prefer to not see the #defines, typedefs, globals or function
declarations. Or is there a different view I should be opening?
Re: Filtering Outline View [message #217694 is a reply to message #217671] |
Mon, 23 June 2008 15:56   |
Hi Jason,
There is an option to hide macro directives. You can access this by
using the menu (the down arrow icon) on the outline view, and then
selecting the Filters... menu item. It provides additional filtering
options (name filter patterns, exclude macro directives, and exclude
using directives). This can provide a partial solution to your
filtering needs.
Alternatively, if you have some time, you could write a custom filter.
For an example of a custom filter, you can take a look at the plugin.xml
in the org.eclipse.cdt.ui plug-in and search for the macro filter.
Jonathan
> I would prefer to not see the #defines, typedefs, globals or function
> Thanks
Re: Filtering Outline View [message #217784 is a reply to message #217694] |
Tue, 24 June 2008 17:36  |
This is the first time I've sent to the cddt newsgroup, so if I've
missed some critical info, be kind ;-)
I'm using Eclipse 3.3.2 with CDT 4.0.x (4.0.3 core) in winxp, configured
to use the cygwin gcc toolchain
I'm having trouble with the outline view. When the following code exists
in a file:
#if defined(_WIN32)
typedef unsigned long sometype;
#endif
THREAD_RET sconnThreadMain(void *arg);
Outlining stops and never displays sconnThreadMain or anything that follows.
However using ifdef instead of if defined works:
#ifdef _WIN32
#endif
Is this a known behaviour?
Is "#if defined(...)" supposed to be supported? It seems odd that it
completely stops the outlining process.
I have converted my simple cases to use #ifdef but other more
complicated uses with compound conditions etc are more troublesome. I'd
appreciate hearing if there are other solutions to this problem.
Cheers
Dave
FUDForum. Page generated in 0.03915 seconds
