Home » Eclipse Projects » Eclipse Platform » Since M7 Key Bindings don't work
Since M7 Key Bindings don't work [message #216390] Fri, 26 March 2004 14:07 Go to next message
Originally posted by: rjs1956.hotmail.com
Since M7 my key binding (Ctrl-A) to do File/Save no longer works. I've
tried setting it up several times in the Preferences/Workbench/Keys tab but
it just won't take.
Re: Since M7 Key Bindings don't work [message #216545 is a reply to message #216390] Fri, 26 March 2004 20:42 Go to previous messageGo to next message
> it just won't take.
Depending on your selected mode (Emacs or otherwise), Ctrl-A is
probably already bound to another function. You have to remove
the built-in binding first, otherwise, the built-in binding always takes
precedence, regardless of your add-on binding.
kk
Not working in M6 - Re: Since M7 Key Bindings don't work [message #216573 is a reply to message #216545] Sat, 27 March 2004 05:51 Go to previous messageGo to next message
Actually, Ctrl-A is not working in M8 (just upgraded 15 minutes
ago), was working just fine in M7 ... what a bummer!
I used the emacs-binding, and was working nicely. Now, the default
"select all" works, but I can't rebind to "line start" anymore.
What is so stupid is, everytime you upgrade, you lose all your
key bindings, and have to rebind everything again :(
And worse, there's this default and emacs key binding, but
even if you select emacs, the default key binding still takes
precedence. What's the point then? And this happens in all
versions.
kk
Re: Not working in M6 - Re: Since M7 Key Bindings don't work [message #216616 is a reply to message #216573] Sat, 27 March 2004 08:12 Go to previous message
> precedence.
This might be related to the bug I just filed (#56453) which prevents me
from modifying the default key bindings.
Thilo
Previous Topic:Installing eclipse
Next Topic:M8 + IProduct + IProductProvider
Current Time: Wed Nov 19 20:21:05 EST 2025
Powered by FUDForum. Page generated in 0.36226 seconds
